223 Bulletins to date
Received 4,438 Likes
'71 Pinto
LI91.16-P-076098 APR23 – 223 w/code 423 or P07 production 7/2022-12/2022 noises from the foldable head restraints of the front seats, replace head restraint.
LI82.62-P-076176 APR23 – 223 w/code 96B static from speakers while driving no longer present after opening a window or when sliding sunroof is in tilt position, check assembly of 4 ‘active driving noise compensation’ sensor brackets to ensure that they do not come into contact with the body.
Recall Campaign NHTSA ID: 23V455 - 2021-2023 S-Class W223 V223 (and others) Fuel Pump Impeller might not meet current specifications regarding its material characteristics. As a consequence, the impeller might deform and contact the fuel pump housing, resulting in mechanical resistance on the impeller. This could cause the fuel pump to stop operating. As a result the vehicle could loose drive power, which could increase the risk of crash or injury. Before the fuel pump is switched off, the driver may be made aware of a malfunction by a warning message on the instrument cluster and might notice a roughly running engine.
As of August 2023, the remedy is not yet available. You will be notified by another letter when the fuel pump module becomes available.
