21” tires and wheels
This is an interesting video, he found the same subjective feel differences that I described (largest diameter wheel had the best handling feel in dry, smallest felt best in wet, but in reality times were very close, he also found the middle tire the best combination of ride and handling and noise, which is what I found when shopping for my S560):
Finally I ended up with 19's with PS A/S 4 and definitely they are more comfortable and floaty due to higher sidewall with 4psi lower recommended air pressure. I don't feel the small cracks anymore and the stopping distance is similar. Maybe 19" may match the corner performance to 21" with higher air pressure, but it might kill some of the comfort. I might test it later and see. Other option was changing 20 winters with A/S, but then again the tire pressure may not be lowered as much due to road conditions though MB recommends same psi for 19 and 20's for GLB35... Lookwise 20" profiles look nicest on the car with AMG brakes, but comfort is better with the smaller 19" wheels... I had 19" Conti A/S on GLK350 and there was no problem with those even with big potholes...S-Class is heavier than the GLB/GLK.
If you want to discuss feel now you're talking about dynamics which is another subject. I'm not going to get into that one too much other than to say the big wheels equal better performance myth is strong and IMO people conflate the wagon wheel feel with good due to the myth at times. You have a generation of drivers who grew up with that myth now; they were raised to think big wheels with low aspect tires is what good feels like. But is it? Different story here than with performance, where the math rules. I'm not going to put myself in a place where I'm telling someone what to like but I would say it's interesting to ask yourself why you like something. It didn't happen in a vacuum.
I am not someone who wants the biggest wheels, or who feels that the biggest wheels give the best performance, but all I have to do is drive the same car on different sized wheels and the difference in how the car handles and feels is clear. Going up in wheel size in general sharpens the handling but hurts the ride. To me its about finding the sweet spot, which I really feel I have with what is on my particular car. I would never buy one of these cars on 21s.
I have driven many S560s on 18s, and they ride a little softer but they also feel a lot looser and boatier which overall hurts the way the car rides to me. I don't want to drive a Lincoln Town Car. If someone prefers that...thats fine...thats why there are options.
As to the rest, I'm not calling anyone stupid. In general, people believe a lot of things based on various "knowns" that are false. I count myself among that group and I catch myself up in it often enough, I don't think I'm clever but I don't think I'm stupid either. The big wheel myth is sold every day because it pays well and few bother to actually check what "everyone" knows; over the course of decades its become entrenched. More so I think because at one time it was true. If I gave the impression that I think people are stupid, I apologize. My intent was to provoke thought.
Let me rephrase: If you, by you, I mean anyone and include myself, like something based on a false premise what does that mean, and would you want to reconsider your position after you became aware? Keep in mind that if the myth didn't exist, you might still like the feel of lower aspect tires better because you may or may not have (wholly or partially) based your opinion on what you believed is better. In the real world however people tend to put strong emphasis on what they believe is better or true and it's hard to shake an opinion once formed. You know all that, what you may not know is that I myself like the feel of low aspect tires outside of comfort; but I can't say how much of that was colored by what I've read, been told, think I know.
I'm not too old to learn, I'll be wrong again, and I hope, do something about it. That boaty feel you mention used to be considered a good thing, the way a car should feel. Was it good? Or did we just tell ourselves it was good? See where I'm going here?
This guy found lap times within a second and the fastest lap time was the largest diameter wheels…how do you reconcile that?
Where you are missing why this turned out this way is the behavior of lower profile tires vs higher profile tires as they slide over in a corner. The less sidewall the less the whole wheel slides towards the outside of a turn while the tread maintains contact with the road surface. Increasing the diameter of wheels does not increase the overall diameter of the wheel/tire combo, that stays the same. The difference is what portion of that diameter is a material that has no give (the wheel) vs a material the deforms when put to a lateral load (the tire). The less the tire deforms under lateral load the more grip the tire has which is why lap times are shorter, you can confidently carry more speed through a corner. Feel is improved because the directional change is more precise since again there is less tire to deform. If you drove the cars flat out you would find that the grip is probably the same ultimately but the smaller slip angle increases handling feel and improves confidence which lets you drive faster.
This is called the slip angle. Lower profile tires have smaller slip angles.
https://www.suspensionsetup.info/blo...ip-angle-truth
From the article:
There's more, but I have to ask myself if it matters? You just tossed out a post which is incorrect at the most fundamental level based on a search that was based on what? A desire to support an argument that defies known physics? What am I supposed to do with that?
These things are real. Go to the truck forums and ask what happens when you throw the big wheels and tires on there. They'll tell you the truck will accelerate slower, your braking distance will be longer, the truck will resist turning due to that rotational inertia you pumped up. The latter can be so great you need to make upgrades to the steering. Think about it. The forces at work are different only in scale.
If you go to the track you'll see the track rats have downsized their wheels to the smallest that will clear the brakes. Doesn't matter if it's the M3 guys, the Corvette owners, Porsche, they all do it. Think it's because they're trying to go slower?
Maybe they're stupid, the real pros run the wagon wheels. Think about what you see on a race car, any race car; wagon wheels or something else?
I don't know where to go here. I like you so I'm going to give you the last word because I'd prefer an amicable relationship with an agreement to disagree to the alternative. Mine is that I didn't make the physical world or the physics that define it. I don't own this; the sun doesn't come up in the morning because I say it comes up in the morning.
I've tried replacing the P-zeros with PS4S, which had thicker side walls. Still blew 2 tires on the first sizeable pot-hole I encountered out of town.
and would recommend to anyone still on 21s
