jump start 12 volt battery
Old Nov 26, 2022 | 10:40 AM
cheenuabc's Avatar
2021 s580, 2025 genesis gv80
Hi,
I have 2021 s580 and I would appreciate if someone can tell me 2 things:
What kind of 12 volt battery does this car have? AGM, lithium or other!! And what are the specs/ part number
can you tell me the negative terminal in the picture for trickle charger or jump starter is what I have marked?
really appreciate
Old Nov 26, 2022 | 11:57 AM
W205C43PFL's Avatar
Originally Posted by cheenuabc
Hi,
really appreciate
Yes what you are pointing is correct for the negative terminal, the positive terminal is under the battery cover under your hood to the upper left, your battery is an AGM battery, part number is A0019828208, you will find this battery in the trunk under the floor cover.
Old Nov 26, 2022 | 02:28 PM
cheenuabc's Avatar
Thank you so much
also---'' you will find this battery in the trunk under the floor cover''. is that the starter battery? then what is in the engine compartment? sorry for me not understanding.
Old Nov 26, 2022 | 03:31 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
All that is in the engine compartment are terminals for jump starting. The starter battery is in the trunk.
Old Nov 26, 2022 | 03:37 PM
cheenuabc's Avatar
Thanks a lot sir for clearing that for me.
