S680 length worries me
Old Dec 24, 2022 | 01:47 AM
SpookyTheFirst's Avatar
S500 / Db9 / F360 / Range Sport V8
Hello,
I discovered with immense pleasure that there is now a V12 that is also 4 wheel drive, 4WD was indeed limited to the V8 engine for the W222.
However, for this you have to take the Maybach version (S680) which is about 20 cm longer than the S550 L version W222 that I currently have…. and that is really not very handy. On the other hand, it has the 4 wheel steering which is supposed to reduce its turning radius by 2 meters…
So, at the end of the day, is this increased length really a problem?
Do some of you owning of having tested the S680 can comment?
Thanks!
Old Dec 24, 2022 | 01:54 AM
TSA's Avatar
TSA
S580 MAYBACH Z223
yes. You should be worried about it. I own s580 maybach and the vehicle is impossible to turn. And if you don’t purchase the 360 camera , it would be impossible to park. The country im currently in has really bad roads so it’s also impossible for me to make an u turn or stuff like that.
Old Dec 24, 2022 | 02:58 AM
Thanks, I don’t which exact version you have but the turning circles I found are: 4Matic S580 12.8m and the S680 11.5m…. so according to those numbers, the S680 would be easier to maneuver than yours?
I may be wrong since both seem to have 4 wheel steering and the S680 is much longer than the S580…
Old Dec 24, 2022 | 03:24 AM
Diesel Benz's Avatar
Those figures look like the S680 had 10 degree rear wheel steering and the S580 had 4.5? Odd but neither option seems standard for the Maybach (in our region at least).
Old Dec 24, 2022 | 07:10 AM
Drone_S213's Avatar
Veteran: Air Force
2021 AMG E63s Wagon
Cool First World Problems?
If I owned a Maybach would have a Chauffeur (or Professional Driver as part of a Security Detail)...and I have a Commercial Driver's License! In the West Texas Oilfields sometimes had to drive in Reverse up to 2-miles off-road just using side view mirrors in a Tractor Trailer with overall lengths up to 70-feet. Did that for Cash after a 30-year Aerospace Career with a Physics Degree...
Old Dec 24, 2022 | 09:08 AM
docsout's Avatar
2023 S Class 2013 SL
Drone, you are too funny! Brought back memories of me working in our Cajun oil fields in South Louisiana in Summer between pre med semesters.
Old Dec 24, 2022 | 11:41 AM
SilberGrau57's Avatar
2004 W240 Maybach 57
So, at the end of the day, is this increased length really a problem? Do some of you owning of having tested the S680 can comment?
Your W223 S680, although having the same wheelbase (133"), is still 10" shorter overall than my W240 Maybach 57 (225" vs 215"). Of course, the W240 doesn't have 4-wheel steering either, but is not scary at all to drive. You simply have to adjust your references. Also, it has ultrasound front and rear parking assist (tone when you get close), so is not "impossible" to park either. It goes without saying that I never try to park it in close quarters, though.
Old Dec 24, 2022 | 11:57 AM
Ormond2004's Avatar
Mercedes S550
I’m sure it depends on the size of your garage and your country.
Old Dec 24, 2022 | 06:59 PM
BenjaminKohl's Avatar
2014 Mercedes E350 4matic Wagon, 2018 Fiat 124 Spyder Lusso manual, 2005 Acura TSX manual
That would be the turning circle for a regular non Maybach S Class L with no rear wheel steering vs a Maybach S Class with presumably 10 degree rear wheel steering
Old Dec 25, 2022 | 03:17 AM
These figures are for a Maybach from one wiki site (https://en.wikipedia.org/wiki/Merced...Class_(W223)):
Available engines are a 4.0-litre biturbo V8 for the S 580 4MATIC and a 6.0-litre biturbo V12 for the S 680 4MATIC. Both are fitted with standard 4MATIC all-wheel-drive system. The rear-wheel-steering system for reducing the turning radius is optional extra cost. The turning angle can be set at 4.5° or 10°, reducing the turning radius from 13.1 metres (43 ft) to 12.2 metres (40 ft) and 11.2 metres (37 ft) respectively.
Seems difficult to find matching figures.
Old Dec 25, 2022 | 03:32 AM
TSA's Avatar
TSA
S580 MAYBACH Z223
it changes with the rim size as i know.
Old Dec 25, 2022 | 05:23 AM
Turn radius depends on the rim size equally for the W/V223 as the Z223 in the sense that 10 degree steering is not available for the wider tyres.
Isn't the 580 Maybach length/wheel base the same as for the 680 Maybach? Anyway, the naming is confusing, people talk about the S580 where I understand they are referring to the W/V223?
Old Dec 25, 2022 | 07:44 AM
TSA's Avatar
TSA
S580 MAYBACH Z223
Isn't the 580 Maybach length/wheel base the same as for the 680 Maybach? Anyway, the naming is confusing, people talk about the S580 where I understand they are referring to the WV/223?
yeah thats the thing im saying
