Remote Vehicle Diagnostics and Telediagnostics
Does anyone know what exactly these features do? Can Mercedes remotely see any created fault codes, including check engine lights? The info button next to these two features doesn’t have any info.
Personally I think that’s great, assuming that info also gets back to the servicing dealer. And if it is true, they shouldn’t be able to plead ignorance on any intermittent issues I would presume since it gets transmitted back to Mercedes the moment it happens.
Diesel Benz (06-18-2023)
I found this: https://developer.mercedes-benz.com/...nostic_support
It seems my assumptions are correct. In fact, MB has an API to make this data available to third parties?
So, someone, I assume MB HQ, can see a lot of car data remotely. What would be even better if this data was made available to the dealer and us, the actual owner of the data. Maybe that is what the API is for? Anyone know anything else about this?
Received 2,616 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Here is an example: https://mbworld.org/forums/c63-c63s-...ml#post8607131
Frenetic (06-18-2023)
They can also remotely wipe codes, which is kind of scary. Also, according to that thread, the data is queried upon request versus a constant stream, at least to the dealers. It wouldn’t surprise me if everything is logged back at MB, though.
So for that reason I think this logging is nothing new (except...), I guess now it is more like the settings on smartphones "Track.... location/usage data/etc." "Send analysis data" "Unique advertising ID" "Unique identifier" but in the case of MB you can't "opt out" via something like "Do not track"
Well, I very least hope whatever data they collect will help improve the products and build stuff that consumers want, not what MB wants or that MB thinks customers want.
Yes to the bolded part of your original post, the rest not sure
Definitely makes it easier for diagnosing the car and so if it is not a serious or safety issue perhaps the customer doesn't have to bring it in just yet and perhaps if for those customers that have stored codes indicating a safety issue it would alert the dealership automatically and so a higher priority appointment is therefore available?
Diesel Benz (06-20-2023)
