2023 S500 check engine light
Old Dec 16, 2023 | 08:56 PM
Bethany1998$'s Avatar
2023 S 500 and 2020C300
I have a 2023 S500 and the check engine light comes on frequently . I have had it back to the dealer several times and they "clear the codes" they have told me to ignore it , they are working on a fix and will tell me when its available. This is not acceptable to me.
Old Dec 17, 2023 | 06:49 PM
garyharbon's Avatar
c class
Welcome to the forum
Old Dec 17, 2023 | 06:51 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W223 forum...
Old Dec 18, 2023 | 01:44 PM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
Talk to a lawyer about lemon law?
Old Dec 18, 2023 | 05:10 PM
Frenetic's Avatar
2023 S500
It’s probably this https://www.tsbsearch.com/Mercedes-B...54-21-P-076055 and it’s a known issue that is supposedly harmless and yes, there is a fix in the works. The light should go off by itself after three+ restart/sleep cycles.
Take the TSB with you the next time you’re at the dealership, confirm your issue is the same and ask if there is any SCN coding updates available.
