Oil Temp Indicator
Old May 29, 2024 | 09:37 PM
Frenetic's Avatar
2025 AMG GT63, 2023 S500, 2022 GLE53
Oil Temp Indicator
Does the blue line below the oil temp indicator mean the oil isn’t at operating temperatures? If not, then what else does that line mean?
Also, I love how the numbering scale they show is kind of pointless since the value of the shown bars are variable.
Old May 30, 2024 | 06:59 AM
W205C43PFL's Avatar
https://cimg6.ibsrv.net/gimg/www.mbw...1cc344248.jpeg
Yes that is what the line means, the filled bar above the line shows what the temperature is currently is and if the bar above the blue line isn't filled, the car is not at the operating temperature, the red as you expect means it is overheating if the bar ever reaches that.
Old May 30, 2024 | 07:59 AM
DonS550's Avatar
2021 S580 4MATIC with Rear Executive Seating Pkg. 4D Entertartainment Rear Screens Pkg.
although the above response was confusing at first (using the word filled rather than past). That is correct; the white bar (above the blue line) is "live" meaning this is the oil temperature in real time. If the white bar is not past the blue line below, the oil is cold and not up to optimal operating temperature. If the white bar goes up to and past the red bar below it, then your oil temperature indicates that your engine oil is overheating.
Old May 31, 2024 | 08:04 AM
W205C43PFL's Avatar
Thanks for clarifying, I realized it is confusing as well.
