Check Engine light code P1B95
Old Apr 30, 2025 | 06:41 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
So back in December I had a CEL pop up on startup. I hooked up my code reader and it showed code P1B95. I cleared it with the reader and it never came back. Fast forward to a couple days ago and it came on again at startup. Checked the code, same code. Cleared it. Couple days later it came on again at startup, so I scheduled a service visit. It cleared on its own the next day and is still off but its at the dealer anyways.
Anybody had this issue and this code before? Googling seems to give some conflicting info. Some data shows its a hybrid battery overvoltage, and some shows its a fuel system issue. Car drives totally normally...
Old May 1, 2025 | 05:51 AM
W205C43PFL's Avatar
Please keep us posted, never heard of this issue and this is the only thread I found, also a W223 but evap system related https://mbworld.org/forums/s-class-w...c-circuit.html
Old May 1, 2025 | 09:00 AM
nearwater4me's Avatar
'25 S580
It can be many different things, but maybe check the EVAP pressure sensor?
Generally, DTCs with whatever 'sensor/circuit low' is related to a bad sensor or module.
Old May 1, 2025 | 09:20 AM
SW20S's Avatar
2024 S580
Its at the dealer and they're working on it. I'll update everybidy
Old May 1, 2025 | 10:28 AM
SW20S's Avatar
2024 S580
Purging pressure sensors, they are replacing both.
Old May 1, 2025 | 11:07 AM
'25 S580
As expected.
Some of these sensors, they just go out without any rhyme or reason.
Glad it was fixed rather quickly.
If possible, could you share the labor time (LTS) listed in the service document after the fix?
I'm interested in how involved it is to get access to these sensors.
Thanks!
Old May 1, 2025 | 11:13 AM
SW20S's Avatar
2024 S580
I will when I get it back, they told me it should be done today
Old May 1, 2025 | 01:20 PM
W205C43PFL's Avatar
Likely defective from factory and just failed altogether when it got worse. Happens, glad they fixed it and happy to hear it is an isolated case for this vehicle.
Old May 1, 2025 | 04:33 PM
SW20S's Avatar
2024 S580
Actually the dealer said this is pretty common.
Unfortunately my invoice doesn't show the number of labor hours.
Old May 2, 2025 | 05:25 AM
W205C43PFL's Avatar
Pretty common? Hmmm, strange as I don't hear it reported on the forums or I missed it or maybe because most of S-Class owners don't visit this forum.
Old May 2, 2025 | 10:37 AM
SW20S's Avatar
2024 S580
Yeah outside of that one other post I haven't seen anything about that either
Old May 2, 2025 | 10:56 AM
W205C43PFL's Avatar
Even forum member streamliner's very flawed 2022 W223 didn't have this issue.
Old May 2, 2025 | 01:27 PM
'25 S580
Forums may be places where problems and issues are blown out of proportion making other members aware of said troubles,
but service centers are where ONLY cars with issues come for service.
If a tech/mechanic maybe saw half a dozen of the failed sensors, he'd think it's 'common'.
I don't think this is a critical or common issue to be sweating over.
Old May 2, 2025 | 01:55 PM
W205C43PFL's Avatar
True
Old May 3, 2025 | 09:46 PM
Frenetic's Avatar
2025 AMG GT63, 2023 S500, 2022 GLE53
This car is buggy. I will get emergency brake assist unoperable messages every now and then that disappear after a restart.
Old May 4, 2025 | 09:27 AM
W205C43PFL's Avatar
I guess you haven't been back to the dealership for some updates to see if it can solve it?
Old May 4, 2025 | 09:28 AM
W205C43PFL's Avatar
In case there are stored codes in the system. Get your service advisor to diagnose it remotely https://developer.mercedes-benz.com/...nostic_support
Old May 4, 2025 | 04:01 PM
SW20S's Avatar
2024 S580
Definitely bugs here and there.
Old May 4, 2025 | 04:48 PM
W205C43PFL's Avatar
Give it some time, maybe all will be good once the facelift comes out.
I mean, most are minor ones now so that's the good part.
Old May 4, 2025 | 04:54 PM
retatt's Avatar
Veteran: Army
You would think with that tool available more dealerships would attempt a remote diagnosis rather than have you schedule an appointment for diagnosis 3 weeks out and then a subsequent appointment another month out for the actual repair. I can envision all sorts of cost savings. IMHO much more efficient.
Old May 4, 2025 | 04:58 PM
SW20S's Avatar
2024 S580
I have not experienced anything that I felt was a big deal at all. The technology is just buggy in spots.
Old May 4, 2025 | 05:00 PM
SW20S's Avatar
2024 S580
I was amazed, they took mine the next day and had it back to me the same day
Old May 4, 2025 | 05:03 PM
W205C43PFL's Avatar
Yes that is the good part.
Old May 4, 2025 | 05:11 PM
retatt's Avatar
Veteran: Army
My home dealer also sells VW’s and Kia’s both of which are a dime a dozen locally. I’m sure that explains the service delays. The nearest M-B only dealer is an hour and a half away. Their service dept is only marginally better. Still, I may end up using them.
Old May 4, 2025 | 05:15 PM
W205C43PFL's Avatar
Wait so they technically isn't an official MB dealership?
