My S580 Clunky Transmission - NO MORE!
To prevent that (both MB and Macan) I usually come to a rolling stop then give it 3 seconds even if the traffic light turns green or at least feather the throttle until the computer knows I want to accelerate then normal throttle. Obviously, safety first, if you notice a dangerous situation, floor the car away from danger and don't bother feathering the throttle, your life is more important than the occasional bang from the transmission.
Last edited by W205C43PFL; Jul 21, 2025 at 10:09 PM. Reason: 5 seconds changed to 3 seconds
I love the 9G-Tronic.
So, maybe the OP is on to something, and if that is the case, then this has to be one of the most dumbest oversight from the factory considering how seemingly widespread this issue is.
I showed it to the tech which I've been talking to and got a very polite and detailed response mentioning that to correctly measure the level one needs to have precise temperature, engage all the gears and other step done and it looks like the topping up was done using drain plug and pressure filler. He also remarked that while technically possible, it's not an official or approved procedure.
I think they are really afraid of doing anything outside prescribed procedures. Frankly, I don't blame them and understand that it's a business decision - the place is always booked weeks ahead, so they don't need to complicate their lives with custom requests.
The device in the video plugged into the bottom of the transmission oil pan is the ultrasonic tool used to measure the exact fluid level in the transmission pan—done while the engine is running (you can her the engine running in the video) and at operating temperature. The other device is the MB diagnostic computer plugged into the car. That tool takes the temperature of the transmission fluid, notes the range that the temperature must be taken at (and likely compensates for that temperature given the fact that transmission fluid expands when it gets hot--just because the engine is warmed up, doesn’t mean the transmission is fully warmed up) and displays the fluid level range of acceptable values.
In summary, the ultrasonic measures the fluid level, the diagnostic tool takes the temperature of the fluid making sure it is in the proper range, makes sure the engine is running, and when those two criteria are met (there might be other criteria as well), uses the temperature and fluid level to calculate the lowest acceptable fluid level, the highest acceptable fluid level and the “specified” or midrange value.
The fluid in my transmission is now approaching the higher end of that acceptable range—and it seems to have made a world of difference in shifting behavior.
During the visit, they also performed recall work that updated the software for the fuel system control unit, replaced the ignition coils for cylinders 1 and 2 under warranty (due to a misfire, had no check engine light), installed new spark plugs, replaced the engine air filters, and changed the transfer case fluid. With all of this work done at once, I'm not 100% sure it was the increase in the transmission fluid that smoothed out the shifting.
