Service Campaign; Secondary air injection pump
Old Apr 28, 2006 | 01:56 PM
GrepAwk's Avatar
'03 S55 (79K miles)
Time to update that TSB sticky, Ricky.
I just received a letter from M-B USA announcing Service Campaign #2006-030011. Effects the 2002-2006 AMG versions of the SLK, C, E, CL, S, CLS, SL, G vehicles. Also effects 2006-06 SLR, for those of you SLR owners slumming around the S55 forum.
Says they need to upgrade firmware in the ECU and swap out a relay for the Secondary Air Injection Pump.
Will avoid a potential malfunction that could render the SAIP relay inoperable, and which would light up the "check engine" light.
Should be a freebie. I'll make them pay ME in coffee and donuts in the customer lounge! Maybe they can dial in a few extra pounds of boost while they are updating my ECU.
Old Apr 28, 2006 | 03:21 PM
AMG_Mike's Avatar
2006 S55 & 97 T88h Supra
had to drop off the s class last nite and i'll be picking it up today afterwork. interesting to see a NUMBER of AMG's at the service dept at one time. Have fun with the loaner car
Old Apr 28, 2006 | 05:53 PM
Wolfgang's Avatar
MBs
Here's some stuff about it:
http://www.alldata.com/tsb/Mercedes-...11B/index.html
Old Apr 28, 2006 | 06:42 PM
vraa's Avatar
I'll see what I can update
Old May 3, 2006 | 03:35 PM
PA55AMG's Avatar
2010 Range Rover S/C 2010 Land Rover LR4 HSE Lux Plus 2007 BMW R1200GS
Make sure your dealer has the relay before you go in. I went in to have mine done today, and they did not have the AMG specific relay in stock. I guess this recall applies to cars other than AMG. I did, of course, check with the parts dept. before I made the appt. and they said " no problem...we got 'em ".
My service advisor also said that the software download and code reset has taken longer than normal, so it may be a little longer than the 1 hour specified in the letter.
He also said this could result in a NON-START situation, so it is worth getting done.
Old Oct 23, 2009 | 10:45 AM
endri sallata's Avatar
sl600 2005
same problem whith my sl600.engine fault came on,it was secondary air pump and i changed it and engine light came on after 3 days.what now?relay?any idea whith the location will help.thanks
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
