S63AMG Lowering/Suspension Options????
Lowering module? Links? Any other suggestion?
What are pros/cons to each option?
Which name brand do you recommend?
Details will be most helpful.
Thanks.
Here are the few ELM's that are in the game.
My List from Top to bottom
RENNtech
pro:
In my opinion the best ELM on the market. Also the lowest priced at $1195.
This is the only digital ELM, that doesn't use a analog signal to raise and lower your MBZ. The issue with analog is that the signal fluctuates with heat.
The ride height can be adjusted with the turn of a knob.
Con:
You need to spice wires for the installation.
Carlsson
Pro:
No spicing, but not an easy install. You must remove the pins in your harness to use this plug and play feature.
Con:
Uses Analog signal, priced at $1675. Somewhat difficult installation
Brabus
Must be spiced, analog signal. $1895 for airmatic, $2290 for ABC
It has seperate adjustments and installs under the passenger floor panel by splicing 4 wires. They have a bypass plug to put it back to stock when you need suspension service.
zteB
