S55 Bose audio adding aftermarket subwoofer
Old Oct 10, 2007 | 06:48 PM
Suprfknman's Avatar
I want to add an aftermarket subwoofer to the Bose system in my 04 S55. I had the dealer disable the "autopilot" auto volume adjust and noise cancellation system. Does anyone know where to get a good signal from? I was hoping to find a full range signal. Also is there a good wire to tap for use as an amp remote turn on. Any help would be appreciated.
Thanks,
Will
Old Oct 11, 2007 | 08:27 PM
Tyler Durden's Avatar
2004 S55 AMG
Thanks,
Will
Here's a for you, 'cause I'd like to know too; the factory stereo just isn't doing it for me...
Are you upgrading the door speakers or doing anything else? Inquiring minds want to know!
Old Oct 12, 2007 | 02:17 PM
Suprfknman's Avatar
I was going to add an amp and sub and see how it sounded then go from there.
WIll
Old Oct 30, 2012 | 11:43 AM
Busta Riles's Avatar
1969 280S, 1991 300E
You can take the signal off the factory sub. It's an easy wire job, as the battery is also in the trunk. It took my stereo guy less than an hour, including hiding my aftermarket amp above the CD stacker.
I am thinking about punching a hole in the wall of the rear seatback where the armrest is, and turning the sub box so it pounds right through. These cars are built so solid, that it is tough to get the bass into the cabin.
Has anyone else done something similar?
Old Nov 4, 2012 | 08:00 PM
hegar817's Avatar
2003 s55
I can not recall where I saw this but someone removed the rear armrest and made a box with either 2 10s or 2 8s. It also it was like an "L" shaped box that curved down where the armrest lays on the seat. I am also considering adding like a 10 or 12 to give it more bass. Can the sub be removed?
Old Nov 5, 2012 | 11:39 AM
I just hid my amp behind the trunk liner, just above the changer and i have a simple box wired in, so i can remove it easily if i need my whole trunk.
Old Nov 9, 2012 | 10:24 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I have an amp bolted to the back panel , insided the trunk and just a 10" sub where the factory sub was. Plan to change out to 12" soon though.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Nov 12, 2012 | 09:48 AM
ItsAdam1's Avatar
04 S55 AMG
Isn't the gas tank behind the rear seats? I plan on removing the factory sub and using that hole to get the sound in the cabin.. I might even build a box and port it threw there...
Old Nov 12, 2012 | 04:41 PM
Viet_Amg408's Avatar
Pinto
you guys cannot put a hole through the rear seat.. because there's aluminum gas tank there...
Old Nov 14, 2012 | 11:30 AM
Good thing i didn't pull out my hole saw, lol!
I just assumed there would be nothing there, as most of our cars have the option for a ski pass-through.
Old Nov 14, 2012 | 01:18 PM
Pinto
the w220 gas tank is big................
it has to be at that location otherwise like bmw, double gas tank..
Old Nov 14, 2012 | 03:11 PM
babyman1737's Avatar
2005 CLK500 cab, 2004 S600 designo mocha
European W220 (and maybe Canada??) have the option for ski pass-through, and option for mini fridge. The gas tanks on Euro w220 are different. Here in the US, the tank fills the entire compartment behind rear seats, so drilling would be bad.
Old Nov 15, 2012 | 06:35 PM
I just confirmed...Canadian models have the same tank as the US one.
Drilling would have definitely been bad!
Old Jan 17, 2019 | 05:01 PM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
Yes I know this thread is very old, but I want to follow up on this idea. Which sub did you use? I know today they have some decent slim fit subs. Any pics?
Thanks,
maw
