houston: hrp 12-16-07 sunday
if anybody wants to meet up let me know...the weather will be ideal for some good runs...similar to the day i ran 11.84 in the 55
gates open at 4...racing begins at 5 and they stop racing at 10pm. $20 to race. i would enjoy helping any first timers as well...hope to see some people from houston sunday!
john
i already had some other plans but i will make it out for the very beginning to get a couple of runs in...
john
i only managed a 12.6, oh well...
what was your best time for the night?
Carlos, as always, good to see you! we will have to get together for lunch this week
How did the 600 run?
TIA, hope it went well
Best et… 12.29 @ 113.88
Best mph…12.41 @ 115.30
I was there for 6 hours and got 6 runs in…it was very crowded…and cold…someone said the DA was -530.
Some observations…
1.the car is very difficult to launch…either bogs or blows the tires!
2.the car likes a little heat in it…the best mph came from the back to back last two runs…plus the first pass from being driven to the racetrack
3.ESP is a must with street tires…the one time I tried without resulted in the slowest time…no traction
4.launching anything below 1500 the car was a pig out of the gate
5.anything above 1800 the tires would lose traction after 30-40 feet and esp would kick in…with esp off it would kill the tires at this point (this is when the turbo’s reached max boost (from my assumption with the butt dyno)
6.MY CAR likes rear tire air pressure…I started with 36 psi…I tried 25 psi and it was a joke…no traction. I bumped the pressure up to 40 psi on the last two runs and it was MUCH better. I have found the same result true on the street. With my e55 i would keep the RE-01r’s at 45 psi all the time and it worked great.
Runs as follows:
1) 1.97 short, 12.298 @ 113.88
2) 2.120, 12.570 @ 113.16
3) 1.970, 12.343 @ 113.82
4) 2.260, 13.042 @ 112.81
5) 1.961, 12.383 @ 113.20
6) 1.978, 12.417 @ 115.30
On a day with less cars the opportunity to make some back to back runs on a track with some heat in it…think I might have been able to squeeze out a 12.1X but the track doesn’t open up again until mid-January. The car was in 100% factory trim…down to the Michelin P/S and the factory mb air filter.
If you’re still reading this, thanks for taking the time…it’s on the lengthy side!
Btw…carlos in is C32 was out…we raced one time…he hammered me the first 660’ but I ended up coming around him…not by much!
Eric was also out in his C32…think he had to leave early…it was nice meeting both of you. no 55's or 63's were out...a **** load of f-bodys, vettes, stangs and imports though...248 cars total.
John
I also had traction issues. It was really frustrating due to the long wait between runs. Anyway, I broke my personal record and I'm happy with my results.
We have to do this again early next year guys. Good times.
60-1.80 2.05
330-5.07 5.47
1/8-7.80@90.38 8.58@89.03
1000-10.14 10.57
1/4-12.100@114.05 12.535@113.74
As I stated earlier that the V-12 turbo cars are very hard to modulate on the launch and its either spin city or a bog just as you encountered. After the
Rennech ECU/TCU there is no such thing as bog because the spool up is so quick. Get some drag radials soon and run the car with perfect traction so you won't get frustrated.
1.977,5.307,8.021,90.85,10.343,12.298,113.88
2.120,5.506,8.248,89.85,10.603,12.570,113.16
1.970,5.330,8.052,90.51,10.388,12.343,113.82
1.961,5.329,8.068,90.04,10.415,12.383,113.20
1.978,5.363,8.107,90.01,10.456,12.417,115.30
didn't include the 13.0 run...usless!
it obvious my short times are killing me!
found a photo of me...and eric from LET motorsports...here
For your first time in the car you did very well..Traction obviously is a HUGE factor. The guys busting off records as you have already mentioned are hitting high 1.6X -1.7X, Your times seem very nice for a stock 600 with street tires. I will not pretend to know anything about launching a 600, I have never driven one.
The track temp likely hindered you as much as your tires. You should check it needs to be 70-120 degrees on the surface anything below 70 prevents VHT from working properly.
Too bad the 55's and 63's failed to show seems like a very close race would have occured :-).
Least you have a feel now and next time you can shoot for your sub 12 pass.
Thanks for posting all the info,
