any way to get a better 60' launch
Old Jun 26, 2008 | 09:59 AM
cutt's Avatar
i have the traction control off but it still feel like something is keeping it from full power
Old Jun 26, 2008 | 11:12 AM
sandiego's Avatar
you didnt tell us which model you have. But I have found on my S65 that when i want to keep wheel spin to a minimum...i just lift the hood and start unplugging wires...that usually slows things down a bit so i dont get too much spin. You know my biturbo V12 is kind of strong!
just kidding.
Old Jun 26, 2008 | 11:30 AM
ohlord's Avatar
That
needs to be solved before you can plan on getting your 60ft. times down.
What do you mean down on power?What rim and tire size?Drag radials?
engine misfires?
ohlord
Old Jun 27, 2008 | 02:06 AM
cutt's Avatar
60'
the model is 03 s55 no misfire just does not leave really strong. after a second or two its gone.
Old Jun 27, 2008 | 03:14 AM
Bsmooth65's Avatar
2008 S63, 2007 Escalade, 2007 Avalanche, 2003 745LI, 2002 Escalade, 2004 Wrangler
I am curious myself. I have an S63 and feel like i get too much tire spin when trying to really get on it. I drive with traction off because it is less annoying when tires spin. anyway to maximize my takeoffs? thanks in advance bsmooth
Old Jun 27, 2008 | 08:30 AM
juicee63's Avatar
2011 twin turboed prius
Ease into throttle rather than hammer, roll into the depress of the pedal.
Downshift rather than simply takeoff in D.
The tire spinning can be fun but it is avoidable. Get a softer R comp tire like the Toyo T1-R or Pilot Sport Cup
Old Jun 27, 2008 | 09:24 AM
ohlord's Avatar
Tire size
Are you going to the track enough to warrant using drag radials?If so get some
rims and tires,you are running 265/40/18's get a set of regular S rims in 17's just for the rear ,leave your fronts the size you have.put 265/45/17 drag radials on the 17 inch rims.Install them at the track. or the day you go to the track.
The tires are going to be the same diameter but the sidewall height is going to be taller.The tire will squat more and absorb some of that wheel spin.
Are you power braking or mashing the throttle off the line from idle?
With all that torque coming down low on the power curve,leave from idle and stage shallow,very shallow.Leave on the last amber and practice,practice,practice.Torque aside remember you are trying to move over two tons off the line and do it as quick as possible in the first 60 ft.After that I figure you are running some good trap speeds on the top end and losing races with the slow 60ft and poor ET.
SCCA member 1967
NHRA member 1967
ohlord
Old Jun 27, 2008 | 08:46 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Old Jun 27, 2008 | 08:47 PM
Hammer, did someone call me?
Old Jun 29, 2008 | 12:55 PM
juicee63's Avatar
HYey man post up sum more pics of yer gals! LOL
Whats up man?
When r u headed back to the ole trackola
Old Jun 29, 2008 | 11:32 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Ease into throttle rather than hammer, roll into the depress of the pedal.....The tire spinning can be fun but it is avoidable. Get a softer R comp tire like the Toyo T1-R or Pilot Sport Cup
The Toyos mentioned aren't R-comps, but the 888s are.
I like the T1Rs....1.6x 60-foots can't be all bad.
Old Jun 30, 2008 | 12:02 AM
juicee63's Avatar
Sorry they are R comp tires but neither are soft like the 888 . Most High performance tires emit compounds, the T1R uses S which is comprised of R and Silica
Old Jun 30, 2008 | 04:36 PM
ChicagoX's Avatar
W211 E55
Really? With a 280 treadwear?
They are NOT r-comp tires. You must be confusing them with the RA-1
http://www.toyo.com/docs/tires/tires...category=sport
These are their R-comps:
http://www.toyo.com/docs/tires/tires.asp?category=comp
I've been running these tires for 2 years, Juicee. I think I can read a sidewall.
Old Jun 30, 2008 | 07:43 PM
BlackHammer's Avatar
2006 E55
I run Toyo T1R's and find the longer the burn-out the better the 60' time.
T
Old Jun 30, 2008 | 08:18 PM
ChicagoX's Avatar
W211 E55
T
Right-on.
I spin mine until first haze, then creep up slowly trying to pull as much rubber off the track as I can.
