Keyless Go memory question
Old Jun 27, 2008 | 10:04 PM
jd986s's Avatar
I have 2005 S55. Question I have is that when I use keyless go, key#1 and key#2 shares the memory positions. I have key dependent feature on and it works fine if I use key in ignition (each key has separate memory) but when I use keylessgo, both keys seem to share the same memory settings. Is this normal for keyless go? This is annonying when I switch the car with my wife and it doesn't recognize my memory positions. Thank you for your feedback.
Old Jun 28, 2008 | 05:17 AM
sprins's Avatar
G55, SLS, smart eq
AFAIK: Yes. The Keyless go with cards and keys work that way. There are three memory positions where the cards share one. I assume the keyless go with just the key work the same.
Old Jun 28, 2008 | 02:43 PM
Suprfknman's Avatar
I thought the dealer could program each key to a specific memory setting.
Will
Old Jun 28, 2008 | 11:01 PM
hubitubi's Avatar
s63, e55
easy way to solve this is to have setting memory 1 for both keys be for yourself and setting memory 2 be for your wife
