sprint booster & filters 12.9@106 what mod next?
Old Aug 24, 2008 | 04:21 PM
cutt's Avatar
03 s55 already did the sprint booster and filters. resulted in 12.9@106. what next?
Old Aug 24, 2008 | 06:53 PM
Oxygen's Avatar
W220 S65 AMG
Phenolic Spacers, Pulley, ECU Tune, Airboxes
Old Aug 25, 2008 | 02:32 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
80mm Throttle Body is a must as well.
Old Aug 25, 2008 | 08:23 AM
cutt's Avatar
SPACERS
WHERE DO I GET THE SPACERS AND AIRBOXES FROM?
Old Aug 25, 2008 | 12:37 PM
SSM AMG's Avatar
2004 S55 AMG
Your time does seem that good for a proper running car. Trapping at 106? Are you sure your pump is working? Before you go to performance invest in some sticker tires. Renntech and VRP for the Air box and evosport and VRP for the spacers. But in my opinion the best right now for you will be pulley and ECU. 50 plus whp with it. Also shop around for it. Stage 1 should not cost anything over 2500.
Old Aug 25, 2008 | 04:37 PM
cutt's Avatar
what should it be running?
temperture was around 90* humidity 85*. it was a very hot night down south. how do i verify if the pump is working correctly? 1.9 short time
Old Sep 28, 2008 | 02:51 PM
cutt's Avatar
new best. 12.75@ 107. 1.92 60''on 20'' rims
temp about 77 degrees
Old Sep 28, 2008 | 03:59 PM
Timeless's Avatar
2005 E55 ///AMG
S55 is heavy...and 20" rims do not help...but I would think you should still be trapping 110+. Definately have your IC pump replaced if you have not done so already.
