03' S55 vs 04' S55 .. help!
What are the differences between an 03' and 04' S55? I know the command is different, what is the new version called and how is it better? Other than that (and a much better ipod interface) .. are there other differences?
I'm seeing a lot of 03's but few 04's and up, so I want to know what I'm missing if I bite on and 03 (and will negotiate appropriately of course!).
Thanks all .. from a hopefully soon fellow AMG'er ..
’04 used the updated Command unit using DVD for maps. Better screen and routing algorithm. ‘04 has more new car smell remaining in it.
If if you get a better deal on ‘03, go for it. There might some day be a premium for the 1st year car when it becomes a collectible....in 2035.
Buy the car with repair history showing the ABC system was recently sorted or repaired. Or otherwise low-ball somebody whose car is resting on its bumpstops and fix it yourself for cheap. (Parts cost money). Another common problem for both years is the air vacuum lines that operate all the door locks/soft close functions.
Rule #1. Don't buy the first year of a complicated new model such as an S-55 as MB quickly realizes a number of things need updating. Much of which done for 2004.
Rule #2. If you can swing it get a 2008 and newer 221 S-Class as soooo much of what was so troublesome in the 220 chassis has been solved.
I wish the supercharged 5.5 liter got used in the 221 Chassis or MB turbocharged the 6.2 right out of the gate. Alas... They figure it out over time.
- squeak noise when clutch engages at throttle up
- front bearing wears out and needs replacement.
- clutch surface wears out and needs replacement (rare)
Same problem for all years. I’ve only experienced the squeak (since new, and still there) These are serviceable items on the supercharger, compared to a turbo failure which usually requires complete replacement and fishing out impeller blades from the exhaust.
And if if you want a supercharger (not a turbo), you have to stay in the W220 S55.
They all need to be maintained. I prefer the supercharger. Loved how my E-55 went. Wish that MB had cooked up a clever way to use one (or more!) to make the bent-12 especially amusing. Alas they did not. In any case.... Turbocharger failures are rare compared with the '80s. We all change our oil and use Mobil-1 or another suitable synthetic. Change the oil in your supercharger. You will not forget the odor.
My point being that cars the engines found their way into got a LOT better in newer cars. Many things MB got right in the 221 that were forever annoying in the 220 + new exciting annoyances in the 221.
