Need dyno mode procedure for 2006 S65
Old Oct 4, 2009 | 06:15 PM
blazeone's Avatar
2010 E350
We tried the posted instructions and it did not work on my friends car. He tried several times and got nothing by holding the reset button down for 40 seconds.
Any ideas?
Old Oct 4, 2009 | 06:40 PM
QuadBenz's Avatar
Mercedes, Porsche, BMW, Tesla
You're supposed to press the reset button 3 times quickly.
Old Oct 5, 2009 | 09:16 AM
sales@eurocharged.com's Avatar
SPONSOR
C63S
+1 The drivers door should be closed and the display should be at the odometer.
Old Oct 5, 2009 | 01:50 PM
Busa196's Avatar
2018 S63, lowered
Actually.....
display must be on odometer as stated above, with door closed.
from the off position, turn the key 2 clicks to right, then back to the off position, then one click to the right, then press the Reset button 3 times. All of this should be done within 5-7 seconds. It'll work
Old Oct 5, 2009 | 03:12 PM
Viet_Amg408's Avatar
Pinto
odo should display "milage"..
Old Oct 5, 2009 | 05:37 PM
W220S430's Avatar
2005 S430
Originally Posted by Busa196
Actually.....
im not sure if there are different ways to do it in either the S430 that i have or the S65 but all i do is turn the key to the right two clicks to the right and press the reset button three times and thats that.. i mean if anything try this way
Old Oct 5, 2009 | 05:50 PM
ShangoAshe's Avatar
2020 AMG GT-R PRO
use the search button...
if you did you would have found at least 3-4 threads teaching you how to go into dyno mode.
its 3 clicks not hold down for 40 seconds!
good luck!
Old Oct 6, 2009 | 07:55 AM
blazeone's Avatar
2010 E350
good luck!
Where is the search button located, is it on the center console or near the reset button
Old Oct 6, 2009 | 02:23 PM
Busa196's Avatar
2018 S63, lowered
Yes, there is. Diff ways for diff models.
