Smog Test Problems w/S55?
Old Sep 25, 2010 | 06:46 PM
amgfast's Avatar
2004 S55
Question Smog Test Problems w/S55?
Looking for some suggestions as to the issue. I have 2004 S55 with Kleemann K1 package. Just had the first request for smog test in CA and they tell me the oxygen sensors haven't switched on. I did have it serviced about a month ago at MB, but have driven it about 800 miles since. Any thoughts as to the source of the problem?
Old Sep 26, 2010 | 02:07 AM
Viet_Amg408's Avatar
Pinto
any recent replacement battery? your readiness oxygen test have not run or passed.
any code?.. possible bad sensor..
Old Sep 26, 2010 | 03:47 AM
ohlord's Avatar
No check engine light
just I/M status not ready for O2 sensors?
Try this portion of the drive cycle readiness protocol
repeat the two steps twice.
1. 02 Sensor Heater Diagnostics (do not interrupt this portion of the test). With the engine warm (greater than 80°C), and the transmission gearshift
lever in Park position, proceed as follows:
- Start engine and increase engine speed to between 2,000 to 2,500 RPM for 2 minutes.
- After the 2 minutes, run engine at idle speed, with no applied load for 6 minutes (Air conditioning OFF, no throttle movements etc).
- After this time period has been obtained proceed to step 2 below.
2. Lambda (02) Sensor Signal (do not interrupt this portion of the test, to be conducted directly after step 1 above has been performed). With engine
temp greater than 80°C, and with transmission gearshift lever in position D:
- Drive vehicle for 3 minutes at 43 mph (70km/h).
Get your own obd2 scanner for 50bucks at harborfreight store so you can read when it is ready and avoid failing twice.
Old Sep 26, 2010 | 12:58 PM
amgfast's Avatar
2004 S55
smog test problem
No code that I am aware of yet, nor recent battery change. The car is back at MB for a diagnostic.
Old Sep 26, 2010 | 12:59 PM
amgfast's Avatar
2004 S55
Thanks for the advice.
Old Sep 26, 2010 | 01:00 PM
amgfast's Avatar
2004 S55
no engine light on
Thanks for your advice.
