Headlamp Condensation
Old May 6, 2013 | 07:36 AM
xabo's Avatar
'20 S63
Starting to noticed condensation in one of the headlamps. Did not see any cracks rock chips. Bad seal?
Old May 23, 2013 | 07:27 PM
MaggieMills's Avatar
From: W. Bloomfield, Michigan (Suburb outside of Detroit)
05' S55 Merc Benz; 03' G-wag 500
Bad seal 100%
Old May 24, 2013 | 02:32 PM
xabo's Avatar
'20 S63
Thanks for the reply. Can the seal be replaced or will I have to replace the lens?
Old May 24, 2013 | 03:53 PM
Craftysince86's Avatar
W211
check around the edges where the two halves of the headlight come together, check for gaps or cracked seals. you can use some water proof clear silicon to patch up anything if you find it.
or you can always bake them open and reseal them completely yourself, sounds intense but i promise you it will probably be harder to take your headlights off the car than to bake them
Old May 12, 2024 | 05:48 AM
gfmerc's Avatar
S65 E320
Headlight condensation
So in the end what did you do ? Did you silicone around them or bake them ?
I am having this problem and the rain is forced in under driving and still can get in from around the top of the clamshell. I was going to put a bead around the top of each headlight, something that can be removed and is flexible.
Old May 14, 2024 | 03:44 AM
Sandygear's Avatar
2004 e500
Reseal with butyl rubber. Can be found at home depot for 6 dollars. Get new lenses while you're at it.
