2004 SS - Brake pedal is quite soft.
Iv not really driven any other S55's to compare this to but despite the fact that people keep telling me its big and heavy car i know its supposed to stop better than that, especially on 8 pot calipers!!! I think my mums diesel Saab has better braking than this, and im not even kidding.
So the question is, where do i start to essentially "tighten" the brakes?
Iv changed the front discs and pads and it hasnt really made any noticeable difference so im wondering what else i could do? I dont think brake fluid has been changed for a while so thats step 1, but from the experience of another car a very long time ago that didnt really make much of a difference. Is there a part that could be worn or needs replacing/updating/tightening etc etc???
Thanks.
Iv had the car for about a year and half now and i havnt changed the brake fluid, im pretty sure it hasnt been changed for a number of years now, so next weekend im looking at changing the brake fluid and hoping for the best. Failing that i will then also change the front discs and pads once again, but parts only from Mercedes this time (expecting this to hurt quite a lot).
That said, your first problem is the lack of brake fluid maintenance. You can try fluids like Endless, Motul, or Castrol SRF. They have reported to produce a more solid brake feel and for all practical purposes eliminate the chance of boiling the fluid on the street.
Next, you can switch to stainless steel braided brake lines. I'm not sure who produces them for the S55, but I'm sure you can have it done. This should again give you a firmer pedal feel and less chance of ballooning a hose.
Back to pads.
If you don't care about dust and some potential noise, you can put in something like HAWK HPS or HPS+ pads. They should have a bit more bite. Absolutely no need to change rotors again.
Back to pads.
As for Pads, the current ones are Textar, produce a fair bit of dust and do a half decent job, but nothing too firm.
I think the first thing in order is a fluid change, followed by just pads and then maybe discs if what your saying is right.
Turned out the pistons in the left front caliper were sticking. The tech said this threw the entire system off. The caliper was replaced, the fluid was changed with OEM fluid, and the brakes were adjusted. Of course the lines, ABS etc. were also inspected at that time.
Now the thing stops on a dime with plenty of proper brake feel as per the AMG profile.
Before this service the car exhibited the symptoms you described.
BTW we change all our MBs brake fluid every year now, or at least have a hydrometer test performed. If the weather/temp where you are goes through large seasonal swings as ours does this is the plan we would follow. Cheap insurance!
it is however the age of the fluid. as the fluid ages it absorbs water which makes it easier to compress and results in spongy brakes.
btw, if your fluid has never been changed there is a good chance that the brake bleeder valves in the calipers are stuck. presoak with some wd40 before attempting to remove and then remove _only_ with a socket or the socket side of a wrench. do not use an open wrench. if they dont budge- do not force as you will either strip or break off the bleeder valves. break the bleeders and you are in for a silly mess of removing the caliper, drilling through the broken bleeder, retreading and often requiring the use +1 size bleeders.
ask me how i know...
Iv been looking through the service history of the car and at about 2 years ago the indicator for the "2 year service" is ticked as done. Looking through the rest of the book shows that the "2 year service" should include a brake fluid change amongst other things. Im not 100% convinced that the fluid was changed the last time this happened.
I hope nothing goes wrong but we will try a fluid change on Thursday night. Will also take the time to make sure all the caliper pistons are moving freely and not getting stuck, and what the general wear and tear state is on the discs and pads.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=271166481693&ssPageName=ADME:X:RTQ:GB:1123
Its listed for all W220 S-class's, including the S55 and even the S65 for that matter. Im not 100% convinced that all the hoses across the entire W220 range are the same, especially the big 8 pot calipers like ours. I could be wrong but i just imagine the S55/S65/S600 hoses to be bigger.
