S65 Fuel injectors
Old Jun 3, 2013 | 11:43 AM
AmorSrdanovic's Avatar
2015 S65 AMG
S65 Fuel injectors
i think my misfire is due to a dirty fuel injector, anyone ever changed an injector on a 65 themselves?
Old Jun 3, 2013 | 12:38 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
it is not that hard. Just a lot of studd has to come off.
did you hook the car up to DAS to see the injector flow rate?
Old Jun 3, 2013 | 07:15 PM
2015 S65 AMG
i havent, i got the check engine light and my dad took the car and had the plugs changed, his mechanic also said the coils were in good condition so i assumed it was the fuel injector, i had the car plugged into and a code for a misfire on cylinder 3 came up, i don't know what else could be causing it. i thought about having the dealer take a look but i don't want to get robbed.
Old Jun 4, 2013 | 09:50 AM
shardul's Avatar
Originally Posted by AmorSrdanovic
i havent.
You should then!
Old Jun 4, 2013 | 10:37 AM
Shifter's Avatar
E55, SL63, ML550
If you throw parts at it your robbing yourself!
Old Jun 4, 2013 | 01:37 PM
Quadcammer's Avatar
96 and 08 911 turbos
not to mention you can clean injectors for far less than replacement. There isn't much to go wrong with an injector that cannot be cleaned.
