Found out this wiring diagram for Bose is the same for my 2006 s55 AMG!
Old Oct 16, 2013 | 12:36 AM
Eric_pcars's Avatar
Mercedes s55 amg
Vehicle Selection Mercedes Benz S430 2000 4DR Sedan
Audio/Video
Standard System
Radio Harness » Standard System
Wire Function Colour Notes Fuse # Fuse Size Fuse Location
+12V DC Battery(Constant) Orange
D2B connections; gray for data lines.
Remote Turn On(output)
Blue/black
Wake up lines on various units are blue/black
Factory Alarm Disarm
Disarms with unlock wire
VSS Wire
Green/black
Amplifier Output » Standard System
Wire Function Colour Notes Fuse # Fuse Size Fuse Location 12V DC Battery Red/yellow 66 25 amp
Fuse/relay module underright rear seat
Remote Turn On (input)
Blue/black
This wire runs between the CD player pin 3 & amplifier pin 8. See notes.
Left Front Mid +
Green
Left Front Mid -
Brown/green
Right Front Mid +
Black
Right Front Mid -
Brown/black
Left Rear Mid +
Pink
Left Rear Mid -
Right Rear Mid +
Subwoofer 1 +
Brown/pink
White
Right Rear Mid -
Brown/white
Center Channel +
Gray/green
Mid-cockpit speaker
Center Channel -
Gray/white
Blue
Subwoofer 1 -
Brown/blue
At Speakers » Standard System
Wire Function Colour Notes Fuse # Fuse Size Fuse Location Left Front Tweeter + Green
Left Front Tweeter -
Brown/green
Right Front Mid +
Green/black
Right Front Mid -
Right Front Tweeter +
Black
Green/black
Right Front Tweeter -
Black
Left Rear Tweeter +
Left Rear Tweeter -
Pink
Brown/pink
Right Rear Mid +
White
Right Rear Mid -
Center Channel +
Brown/white
NCA
Center Channel -
NCA
Subwoofer 1 +
Subwoofer 1 -
NCA
NCA
Notes
CD CHANGER is powered at pin 2 thru a red/yellow wire; the fuse is no. 61 of 10 amperes in the fuse/relay module under right rear seat.
The amplifier has microphone connections at pins 1 (white) & 3 (brown).
BLUE/BLACK wire between the CD player & amplifier also goes to the command actuation/display control module in center of dash.
The VOICE ACTIVATION CONTROL MODULE is powered at pin 1, and the D2B interface at pin 4, thru pink/red wires; the fuse is no. 15 of 7.5 amperes in the fuse box in left rear of engine. Accessory wire for the D2B interface is black/pink at pin 5 & the fuse for this is no. 23 of 7.5 amperes in the fuse/relay box in left rear of engine compartment. D2B wires between the various units are orange.
Legend: * iC info * ∆ iC info awaiting approval
Speakers
Location
Front Doors
Size
Depth
5 1/4 ''
Rear Doors
6 1/2 ''
