Brake disc question
Old Oct 25, 2013 | 08:19 PM
gransodomizador's Avatar
S55 amg
Brake disc question
Hi I bought this pair of ferodo disc for my s55k but if I look at the pic they are in the same side I mean loking at the pic when you put on the discs booth arw with drilled in different sidest. Then one will take off heat and the other will keep and earn heat
Is it normal? They shold be in the same direction not?
Cheers
Old Oct 26, 2013 | 12:03 AM
rocko's Avatar
06 S55 AMG
I'm not sure about the rotors that you bought. But I know that the original rotors that AMG made for the S 55 has the same orientation.
If you want them to be directional, you might have to resort to 2pc rotors like Racing Brake's or the company that makes Evosport's 2pc rotors.
Old Oct 27, 2013 | 07:55 PM
S55 amg
Hi
Yes i check pics and my car of course and tehy are the same... But this is strange. Even the e55 ara the same but other brands make same directional but not amg?...
Old Oct 27, 2013 | 08:42 PM
rocko's Avatar
06 S55 AMG
As far as I know the only AMG rotors that they make directional are 2pc rotors for the E63 and the 65 AMG's. I believe those are expensive and you might have to modify your caliper mounts to fit the 65's in our 55's. I'm not really sure if they are a direct fit.
I'm not quite sure why Mercedes designed their rotors like this. Maybe as a cost cutting measure? Hopefully someone in here can chime in.
Old Oct 28, 2013 | 02:02 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
In reality, the holes do not do much on a street driven large 4 door sedan that is not road raced, so if they look good, you like the price, then would not worry about hole orientation. I went with custom 2 pc rotors with slots on mine, as the holes were always cloged up anyway.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
