Coolant leak found. Has anyone had this fixed?
Old Dec 12, 2013 | 10:44 PM
richvegas's Avatar
2016 S65 AMG coupe, 2010 E63, 2015 Z06/z07 m7 vert 735rwhp, 2000 f-350 crewcab w/ 16" kelderman kit
So after seeing coolant on the ground for a week I finally had the opportunity to diagnose it. I pressure tested my intercooler system and there was no drop in pressure. Then I tested the engine cooling system and saw a small drop in pressure. I knew it was coming from the drivers side so I took the airbox out and the turbo out let tube and found it! Appears to be a hard coolant line going into the top of the turbo.
I removed the bolts holding them and can get them out. I think I need to remove the coil pack to get clearance. I imagine there is an o-ring that needs to be replaced.
Anyone experience this?
Attached Thumbnails Coolant leak found.  Has anyone had this fixed?-image-1496516444.jpg   Coolant leak found.  Has anyone had this fixed?-image-2539917749.jpg
Old Dec 13, 2013 | 01:41 PM
vee12's Avatar
W221 S65, W140 S600, W210 E430, W126 300SD
I have the same issue. Dealer and my Indy say MB does not offer just the seal...and must replace the entire turbo....at $4200 per side (parts only, no labor) What a bunch of bull s@!t. I would be VERY interested in your repair results.
Old Dec 13, 2013 | 02:27 PM
richvegas's Avatar
thats obviously not going to happen! lol
i'm going to pull the coil pack out and see if i can get the pipe out and then just put an o-ring on there and call it a day. i will post back when i'm done it with some pics. looks like sunday before i'll have more time
Old Dec 13, 2013 | 05:56 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
common problem on the M275 TT
there is a seal you can replace.
Old Dec 13, 2013 | 07:18 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
WOW wtf, they want you to replace the whole turbo when a seal goes out.... well replacing just a seal shouldn't be hard to do yourself
Old Dec 13, 2013 | 07:26 PM
richvegas's Avatar
it doesnt' seem that bad, as long as i can lift the line out after i remove the coil. ran out of time last night
Old Dec 14, 2013 | 10:16 AM
richvegas's Avatar
have u done it? is there room to get it out after i remove the coil?
Old Dec 17, 2013 | 11:17 PM
richvegas's Avatar
Coming along, but a total pain in the ***!! Had to remove the coil, unbolt the intercooler hard line, and bend the heat shield. Only to find that if doesn't appear to be just an o-ring, getting the part from the dealer tomorrow I hope so I can finish this nightmare.
Old Dec 18, 2013 | 09:56 AM
shardul's Avatar
like you said it is a PITA
Old Dec 18, 2013 | 01:09 PM
richvegas's Avatar
New parts came in. Can't wait for the fun of installing
Old Dec 20, 2013 | 11:38 AM
richvegas's Avatar
pain in the ***, but all back together and not leaking
Old Dec 21, 2013 | 03:28 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
part numbers please!
Old Dec 21, 2013 | 03:35 PM
richvegas's Avatar
o-ring 028-997-79-48
gasket 275-187-05-80
$8 total
Old Dec 22, 2013 | 06:41 AM
DRTYLNDY's Avatar
Nice job dude!
Old Feb 27, 2014 | 08:02 AM
vttt's Avatar
SL600
This just happened to me. It was the passenger side turbo hose that was leaking coolant. I had it diagnosed by the dealer who said that all i needed to replace were the same parts as richvegas. Total labour is estimated at about 3 hours. I asked the tech if coil packs were removed and he said no. It looks like it was relatively straight forward, at least on the sl600 (2005).
Old Feb 28, 2014 | 11:29 AM
richvegas's Avatar
only 3 hours of labor is generous. i know taking out the coils was necessary on mine.
Old Feb 28, 2014 | 03:05 PM
june82000's Avatar
'05 E55
Nice work. Good to see some actual wrenching going on here. Considering getting into a W220 S55 myself - literally drooling thinking about owning one...
Old Apr 8, 2014 | 07:49 AM
vttt's Avatar
SL600
I actually went into the garage and thw mechanic showed me what he had done since the same thing happened on an s600 that he was working on at the time. They ended up doing both sides on mine so the total labour was 6 hours. The s class he was working on was a 2007. My sl600 is a 2005.
Old Feb 9, 2026 | 05:01 PM
KristianFig's Avatar
Scion Tc
damn
This is so cool to see I just got my 07’ S65 and I noticed like once every other week I get a refill coolant alert on the dash on cold start. It’s only got 69k miles so I’m worried there’s tons of **** I’m gonna have fall on me to repair😩
Old Feb 9, 2026 | 11:42 PM
JohnLane's Avatar
222 S-65
I got to do this for my 222 S-65. Passenger side. O-rings for coolant lines. Pretty easy. I used a piece of Brillo pad to polish up sealing surface the o-ring fits to. Clean up with water. Worked well. Two hours start to finish.
