Question about replacing N47-5 ESP Contoller Module
s55 AMG
Hi guys anyone know whats the procedure for removing the "N47-5 ESP Contoller Module"?
Indy shop said my module is bad so I was thinking can I just get the same model # module from lets say ebay and just do a quick swap; plug and play?? or do I have to get it re-programmed by a star diagnostic tool?? I attached a pic of the location of the module.
Thanks in advance for the info.
s55 AMG
Update:
![Cheers](https://mbworld.org/forums/images/smilies/cheers.gif)
Update: I removed all 3 plugs and sprayed CRC Electronic Cleaner on the pins and the plugs and plugged it back in, and WALA!!!!! My ABS,BAS,ESP lights are all gone. Everything is working perfectly as it should. I dunno if there were some debris in the Pin holes or it wasn't seated properly but CRC spray did the job. I always had good luck in using this spray to bring electronics back to life, lolz, but anyhow hopefully this will do the trick.
***CRC Electronic Spray is just a Temp fix. I found out the hard way bc the ABS light came on again right now, POS Module on the fritz; going to swap it out.****
s55 AMG
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
