Rear wheels wobbling?
So I realized quickly after that that I should get it to the shop as fast as I could. Originally thinking it would need another alignment because maybe they had done something wrong the first time. But then the guy called me and said that the vibrations could have been because of the wheel bolts (that the spacers came with, replacing the stock ones) being too long. But he rebalanced the tires saying two were off and sent me off with that...
Only problem is my wheels are stilling wobbling, and I don't want to drive it around if its going to cause damage, even if the vibrations aren't bad right now. And I just have a hard time understanding how wheels bolts that were supposed to be used with the spacers are causing the wheels to wobble as much as they are (I'd say 1/4 inch)
Does this make sense to you guys and do you think the fix is as simple as replacing the bolts? Just nervous there's not something bigger going on that's going to cost me a lot of $ like a bent axle or something like that.
Please let me know what you think
