Low rpm on s65 riding issue
Old Aug 21, 2014 | 04:28 AM
PaulGlaster's Avatar
2007 S65 amg
Hello guys!
I own an 07 S65 with 129 K on it approximately.
Have a problem from time to time after driving the car hard for half an hour or so the car starts acting up id pull up to an intersection and it'll do a move forward kind of while being stopped or while driving slow it'll pull forward a bit and then when i press gas it doesnt go higher than 2-3000 rpms, at the same time i see the outside temperature sensor going bananas from +50 to +20 back and forth.
What would be the correct thing to test out to eliminate this issue?
At times i see an ABC not active as well??
Best regards!
Old Aug 21, 2014 | 07:29 AM
triniexr's Avatar
2011 Mercedes S63 AMG
I would take it to the dealer, you may have some type of electrical issue.
Old Aug 22, 2014 | 05:35 AM
DRTYLNDY's Avatar
I would test the battery.
Old Aug 25, 2014 | 07:39 PM
corsaschnell's Avatar
S65 AMG
Could be a bad temperature sensor. If the ECU thinks you are over heating, it will downgrade your performance to limp mode. If indeed your engine temp is overheating then the solution is simple sounds like it is not but the sensor is sending a bad signal to ECU.
Old Aug 29, 2014 | 10:51 PM
azizblue's Avatar
2011 s63 amg
one of the reasons i sold mines
