2006 S55 will not spin the tires!!!
Old Jan 3, 2016 | 11:08 PM
Eric_pcars's Avatar
Mercedes s55 amg
I took my s55 for a drive today and from a complete stop without traction control and with traction control I get the same results, it will not spin the tires! I've tried it in drive sport and in 1st manual! I've done ecu reset and still same result! I floor it and it doesn't rev, it just pulls off sluggishly. Don't know how long it's been that way but before I could smokem pretty good! What could this be?
Old Jan 4, 2016 | 08:29 AM
Welwynnick's Avatar
2006 S600
Is the intercooler system full of coolant?
is the intercooler pump working?
Is the supercharger clutch engaging?
Is the transmission nproperly topped-up?
Nick
Old Jan 4, 2016 | 02:12 PM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
Sounds to me like no power from the supercharger, so it's acting like a basic V8. I'd start with the supercharger clutch, since that's a known item.
maw
Old Jan 6, 2016 | 11:08 AM
Eric_pcars's Avatar
Mercedes s55 amg
Intercooler pump is working great!How do you check to see if clutch is engaging? Transmission topped off?
Old Jan 6, 2016 | 01:22 PM
maw1124's Avatar
Have you scanned the car for codes? If not, you should start there. Otherwise, with the car in park and running with the hood up, have a friend bring up the rpm and see if the supercharger pulley spins any faster than with low rpm.
Depending upon the mileage of the car, the transmission fluid should be changed; not simply topped off. Consider this an every 5 year, 50k mile service, more frequently if you drive it hard (which, if you're TRYING to spin the tires, I suspect you do).
Or, you can take it to an experienced indy and let them deal smartly with it.
maw
Old Jan 6, 2016 | 10:22 PM
Eric_pcars's Avatar
Mercedes s55 amg
The clutch assembly is barely moving, it moves a little faster at higher rpm! Where can I find a replacement clutch assembly?
Old Jan 8, 2016 | 01:06 PM
maw1124's Avatar
Dealership; Peachparts.com; Ecklers MBZ parts; Or you can upgrade and get more power -- Eurocharged; ASP Pulleys; guys on this site.
maw
