Oil Overfill Damage?
Old Apr 25, 2016 | 04:19 PM
bperez2014's Avatar
2007 Mercedes S550
On the last oil change on my 2007 s550 (w221), the oil check shows too much oil was put in. I have taken out enough oil to make the measurement right. What damage can be done by putting too much oil in?
Old Apr 26, 2016 | 01:25 PM
JoeNobody's Avatar
Mercedes
The excess oil can be sucked through the intake crank vent and into the cylinders. Ring damage can occur if I remember correctly.
Old Apr 29, 2016 | 01:04 AM
hvacdude's Avatar
2006 CLS55AMG & 2005 S55AMG
How much oil over the spec ? More than 1 qt ?
Old Apr 30, 2016 | 03:43 PM
bperez2014's Avatar
2007 Mercedes S550
JoeNobody, thanks for the information, bad as it is!
Hvacdude, I took out about 2 quarts!
Is there any way to check if damage was done? If I take it to Mercedes, can they do something to check or will they just run diagnostics and charge me?
Old May 1, 2016 | 12:27 PM
JoeNobody's Avatar
Mercedes
Have a compression test done. If that looks good then you are probably just fine. If compression doesn't pass you need to rebuild motor or replace ðŸ˜*
Old Jul 13, 2016 | 09:28 PM
my67AMG's Avatar
01 E55
vin
WDBEA32EXSC154051
Old Jul 14, 2016 | 07:46 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
If it was enough oil to hurt anything, and for long enough, you would have noticed a blue cloud of smoke following you around.
Old Jul 15, 2016 | 09:26 PM
my67AMG's Avatar
01 E55
oil
Who did oil change,, should be 8.5qts. Never want to over fill
Bad news!!!!
