Aux air {smog} pump on kompressor engine
Old Aug 29, 2016 | 09:57 PM
hvacdude's Avatar
2006 CLS55AMG & 2005 S55AMG
Where is the aux air pump, smog pump, on the M113k AMG engine located ? On the S500 the smog pump is right out in the open, front and center of the engine. On the AMG compressor engine, the vacuum check valves inlets are connected to the kompressor assembly. Where the heck is the air pump on the S55 AMG ? Is it under the coolant reservoir, on the front left ? I can't find it. First pic is the Kompressor engine {M113K}. Second pic is of the M113 non Kompressor engine {S 500}. The pump is clearly visible on the non Kompressor engine, I can't find it on my M113K kompressor engine in my '05 S 55 amg.
Attached Thumbnails Aux air {smog} pump on kompressor engine-airpumpvalves.jpg   Aux air {smog} pump on kompressor engine-s500airpump.jpg
Old Sep 4, 2016 | 09:00 PM
hvacdude's Avatar
VIN # WDBNG74J95A452526
Old Sep 6, 2016 | 12:55 AM
hvacdude's Avatar
Will do . Thank you.
