Replacing Front Shocks, Control Arms, Accumulators
Old Sep 28, 2016 | 12:25 PM
jpw_amg55's Avatar
BMW M5 / SL55 AMG
I'm in need of replacing Front Shocks, Control Arms, Accumulators on my 2004 SL55 AMG with 85,000 miles.
From what I have read, the shocks are fairly straightforward. What about the lower control arms? Easy DIY? - I am fairly competent with a wrench - have built several engines and restored other vehicles - just don't want to get into this and find I need special tools or equipment....
Rebuilding front valve block at the same time. Where are all the accumulators located? I believe two are on the valve blocks (front and rear). Where are the others?
Thanks in advance!
Old Sep 29, 2016 | 09:03 AM
w4sim's Avatar
S55K AMG
You'll be better off posting this in the SL55 section rather than the S55 section as it is now. More chance of a reply.
But from what you have said about your skills as a mechanic, this should be a fairly straight forward job.
Old Oct 1, 2016 | 01:34 PM
Welwynnick's Avatar
2006 S600
For that sort of work its definitely worth getting a copy of WIS / EPC from eBay etc.
