M113k Manual gearbox, standalone build thread.
Do you have the information on how many teeth the crank trigger has (I believe it has 2 teeth missing as the signal) and also what the relation is to TDC (ie 90 degrees, 180 degrees etc)??
The offset is 11 teeth, meaning the crank sensor sees the missing teeth at 66 degrees before the #1 cylinder hits TDC. I haven't measured this myself yet, since I don't have an engine laying around, but that's the information I got from loggato and it's what I have programmed right now.
This information is invaluable. I finally got back on my project so Im hoping to get the engine running in a few weeks
Ive recently finished my project on Lexus IS mk1 with m113 5.4 n/a and 716.667 gearbox, using Vems standalone ECU. The car is for a drift competition use and l am slightly worried about the gearbox limits, yet after a few practice sessions all seems OK, except we can not reach the real potential of the engine. Been dyno'ing it couple days ago and we are lacking of engine performance... at least 100hp and 100nm are missing... Currently running on E85. Not sure where this came from and my Ecu programmer seems to be lost here. Have changed the spark plugs, bigger injectors and all the engine maintenance is done so a bit confused about where did we gone wrong. Sparks are firing at the same time, but the engine seems to wrestle some issues at the low revs, also not reaching its potential at highs.
Any ideas?
Also, been searching for 716.667 gearbox limits over the forums but could not find any decent info. I can see some guys going for it on m113k, but how long does it last?
Appreciate any comments
Thanks!
Thanks!
It was running pretty rich at first. I've adjusted a few things since then and idles and runs a lot cleaner now. Hopefully a professional tuner will get it roaring.
I'll try to collate all of the information soon on wiring and set up for anyone else that is going to run a Haltech ecu on one of these engines (or similar)
currently swapping a 6 speed from a Crossfire into it.
This is awesome! I saw your video below of it running on the stand, and your work with the manual trans. Gotta say I'm impressed. Hoping you can offer some Insight to a problem having. I'm currently fitting an elite 2500 on a m113 in an 06 slk55 amg. How did you make your ignition system work? Right now I have mine set up on a Hpi8 to the factory coils, but can't get enough spark to run. I can get it to start if I run bank 2(cyl 5-8) on the factory ecu and bank 1 (cylinder 1-4) on the haltech, but it only runs in limp mode. Won't accept any throttle input and runs extremely rough. It won't run At all on all 8cyls through the haltech or with the factory unhooked from bank 2. I've got 12v to pin 2 (center pin) and hpi8 trigger outputs to pin1 and 3 on the factory coils. Any help would be greatly appreciated.
I ran 2 x hpi8 ignitors on advice from Haltech. I split the output from the ecu for each coil and sent to both HPI boxes.
First few questions would be - how are your crank and cam sensors configured? I had no spark at all at first as that was all set up incorrectly. I'll post my set up in a few mins too.
Second is do your coils have 1 12v positive wire each? The HPI units are used to ground the coil(s) (since there are 2 coils in each unit on the merc) to make them fire
yes, they each have the 12v from the main harness, since I'm wiring in parallel, haltech told me to use that for my 12v. Rick from haltech did a remote in and set my crank and cam patterns himself, but I believe they're set to crank: 60-2 missing tooth, full sync, and I can't remember what the cam is set to at the moment. I have the coils wired as 12v to the center pin and 1 hpi output wired to each outer pin on the coils. Thanks a ton. I'll be watching for the setups you post.
https://drive.google.com/file/d/1tI5...ew?usp=sharing
https://drive.google.com/file/d/1Vbu...ew?usp=sharing
https://drive.google.com/file/d/1zOi...ew?usp=sharing
https://drive.google.com/file/d/1ys_...ew?usp=sharing
I'm not sure where to even set the dwell. I havent seen that setting anywhere, but ill look for it also tomorrow, while checking the others. Thank you for that, Joe.
checked all the settings today and they were all pretty close to what you have shown. I went ahead and changed the few different settings to match, but no dice. I checked voltage at the 12v (center pin) on the factory harness and as soon as the haltech powers up, the ecu pulls the 12v, so I wired in a relay into the ignition circuit and tried to start it. Still no start, but I didn't pull a plug or coil to check for spark yet...out of play time for today...I emailed Rick @haltech to see if he has any other ideas...I never could find where to set any dwell time in the settings though, all I see is constant charge but no option to change that, at least that I can see.
Have you confirmed you're getting a spark now? I ran mine first with no plugs in the engine. I just plugged 2 into one of the (pair of) coils to confirm I could see it sparking.
https://drive.google.com/file/d/1I3j...ew?usp=sharing
