E42AMG???'s S55 update
Guess im doing a adapter plug soon
On a positive note I installed a smaller 74mm sc pulley and belt wrap kit.
Also no longer have the chirp on acceleration
Transmission flush was done two years ago, I'm assuming the color is also due to wicking its way threw the harness and picking up contaminants on the way.
Mocked it up and started to modify the snout too get the full potential of the 90mm throttle body
Working on fitting long tube headers, the 3k s55 ones didn't seem worth it so I'm taking the gamble with the cheapest e55 set.
Passenger side installed, two small issues the first is it hitting on the heat shields for the subframe, which doesn't really need it and the bolt that secures a heat shield. So I removed the bolt, there was 3 others holding it in. I chopped the section of the heat shield that was rubbing and gave the tube closest a little taparoo with a hammer, for a grand total of almost an inch of clearance.
the end of the header was hitting the floor pan. I started hammering but that was to slow. Purists beware, I used a floor jack too push the floor up and it worked great. Driver side soon to come.
Trying to get the driver side studs in for the header was causing issues so I just had to walk away. But here is some pics of what's going on
Passenger side officially bolted up.
68mm supercharger pulley
belt wrap kit
90mm throttle body
550cc injectors
split cooling system
big *** pump
meth injection
inline air filters
colder plugs
long tube headers catless stock mufflers
3k stall converter
tcu tune
ecu tune of course
