Changed oil, Now i have lifer tick. oil filter??
Old Jun 6, 2017 | 12:39 PM
AMGK1NG's Avatar
2004 clk55
before this last oil change i ran a quart of atf through it no change, i think i need lifters... Is there a diy or something that would help me out? My car didnt come with a manual.
Old Jun 6, 2017 | 12:57 PM
pumpedTSI's Avatar
BMW E31 Dinan Stage 3 TT 625Hp on 93 pump............. 00 BMW E38 750iL.....03 S55 Alabaster white
Bro,
I have no idea if it will work on YOUR car......all I can tell you is that it worked on mine (and my wifes truck). So if it doesnt work you have bigger issues that will cost bigger $$$ (lifters) so a bottle of seafoam, oil and a filter along with 10 mins of your time is a helluva lot cheaper than the alternative but its your car and your call. The reason I asked about previous oil changes is that the filter is installed a SPECIFIC way using the two black lines on the filter (thats why they put them on there).....google it. In short MY suggestion (that has worked for me) is a correct MANN filter install and the seafoam additive.....you can remove the filter housing cap now and reseat your existing Mann filter then use the seafoam. If this doesnt work you may be SOL.....good luck...
Old Jun 6, 2017 | 08:37 PM
E42AMG???'s Avatar
E420
Mine has had this noise since I owned it and I beat the crap out of it, hasn't gotten worse or better
Old Jun 6, 2017 | 11:12 PM
pumpedTSI's Avatar
Mine was more of a noticable "tap" rather than a tick.......like a collapsed lifter that didnt repressurize after the oil change. Totally disappeared with the seafoam additive.
Old Jun 7, 2017 | 08:55 AM
AMGK1NG's Avatar
2004 clk55
I think im going to just rebuild the lifters, I will be taking pics and will maybe right a DIY because ive been searching for one with little luck, if someone can point me to one please do so lol. Mine is more of a tap to,.
Old Jun 10, 2017 | 01:12 AM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
Try some Marvel Mystery Oil for 500-1000 miles before the next change.
There a a lot of rotating and reciprocating parts making noise under the hood unrelated to the valvetrain.
PZ Platinum Euro or the 0w-40 Viper spec is a top rate oil. A thicker oil may mask the normal valvetrain sounds a bit. MaxLife 10w-40 or any 15w-40 HD oil is a good bet unless it's cold.
