Removing the TCU
Old Aug 30, 2017 | 11:01 PM
cmpcpro's Avatar
2004 CLK 500
Removing the TCU
Hey guys, what's the best way to get my TCU out? It seems sandwiched between the fuse box and the actual fuse panel. Should I be disconnecting the battery first or can I pull up the fuse panel and get to it that way? Seems there is that little gold arm on the front of the fuse block that I can pull back and I assume the whole block will come up? Thanks!
Old Aug 31, 2017 | 12:27 PM
E42AMG???'s Avatar
E420
No need to undo the battery. Unplug the two harnesses and it will pull up.
Old Aug 31, 2017 | 01:52 PM
cmpcpro's Avatar
2004 CLK 500
Originally Posted by Plutoe
That is very bad advice, disconnect all power-----and by the way why are you doing this?
I replaced the TCU with a tuned one from DTK. They too said there was no need to unplug the battery, there is no power going to the TCU with the car off. On top of that WIS shows to pull the codes and then unplug it as I said, with no mention of unplugging the battery, so I'm not sure why you said it's bad advice. It's based off exactly what MB says to do, although if it would have involved moving the SAM anymore than the inch I did I probably would have disconnected just to be safe.
Old Aug 31, 2017 | 04:14 PM
cmpcpro's Avatar
2004 CLK 500
I am older than you and taught differently. I'll FA with the ex wife's car but not mine or a customers!
Oh I agree on being careful and my instinct was to unplug the battery to be safe but MB said not to in WIS and electronics wear the most when power is introduced to them so if I don't need to according to the manufacturer I feel safe.
Old Aug 31, 2017 | 06:30 PM
E42AMG???'s Avatar
E420
I've done it multiple times no issues.
