05 S55 - Brakes smoking
The brakes started feeling a little weak during deceleration from high speed. Thought this may be due to brake fade. After my last deceleration when I came to a stop, I saw smoke coming from the front wheels. I was right around the corner from home so I drove slowly. During these last few moments of driving, it took a lot more pedal effort to slow down the car and bring it to a stop.
Note that the pads and rotors on all 4 corners have less than 5k miles on them. I don’t normally drive my car hard, so not sure if this was part of breaking in the new parts or if there was some other serious problem. Will check brake fluid level tomorrow mornings.
Thoughts...?
Smoke after several stops from three digits certainly got any of the oils in your fresh brake pads and rotors burned off.
5000lb cars need bigger brakes. They always need more.
GL
maw
P.S. With proper brakes on these, the tires should damned near skid to a stop. No joke, I get rubber on hard braking from those speeds. If that's not happening (and your experience tells me it's not), then first comes fluid, then comes hardware. In over 8 years and almost 100k miles, I've NEVER had spongy brake feel on my car, from any speed.
The problem with these alloy calipers is that they have steel wear plates above and below the pads, and the calliper tends to corrode under the lower plates, lifting them up.
Therefore the pads are squeezed vertically, and aren't free to move in, and more importantly, out.
Take a look, Nick
GL
maw
Maw.... SMOKE is due to oils burning off of fresh brake parts (happens once with new brake parts) or brake pads gassing due to being abused. Fluid has nothing to do with smoke. Cheesy brake pads will sign off sooner then brake pads with a 'Performance compound.'
Fresh brake fluid boils at a higher temperature then old fluid for a firm brake pedal... We should be changing fluid at least every two years.
Cheers,
maw
Cheers,
maw
Many times I've parked the car in the garage... Step out... *sniff... Yup! A good morning! Usually it is burning tires.
