Power issues after acceleration
97,xxx miles
Eurocharged tune
Randy
Randy
Thanks for the help
97,xxx miles
Eurocharged tune
but still run perfect except it just sounds different. No codes or lights. Turn it off and back on again and she was back to normal. Right before I put it away for the winter I brought it to a MB expert and he plugged her in. No codes. no issues at all that he could find with the motor. They then checked the trans and all the values looked good. I have also changed all the plugs, both coil packs and had the trans serviced to try and figure this out. Nothing seemed out of place. nothing.
Just a couple of weeks ago I decided to start the car and move it. Started right up and sounded very strange to me, just like it did when it was having the lose of power issue. Then all of the sudden the check engine light finally came on. I did a quick code scan and I am getting random miss fires all over the place.
I now believe that my voltage transformer is failing and has finally shown it's true colors. Since the car won't move for at least 3 more months I have time to order a nice rebuilt VT from Clark.
BTW, I also have a Eurocharged tuned ECU and TCU.
Good luck
Johan
My 275 does a crappy hot start after it hot soaks. I'm told is due to low fuel pressure left in the rail after it is shut down + the way Ethanol likes to boil. Annoying but I know what it is. When it does it really bad I will get a check engine light. Grrrr.
M275fan you describe a tire vibration. Balance them or replace with Continental DWS. Love mine. Quiet. Grip dry, in the rain and don't have to park it when it snows.
Probably will have to wait until give or take April to try.
Johan
