2006 S55 AMG Transmission Flush
Old Mar 21, 2020 | 08:13 PM
  #51
Jdfreak2012's Avatar
2006 S55 AMG
Trans fluid
So I finally got around to checking the trans fluid level with the dipstick I ordered. My 2006 S55 AMG was shifting funny. I looked at the level with the car warm and had to add a whole liter of Pentosin trans fluid. Does that sound right? Could the trans have been that low?
Old Mar 21, 2020 | 09:15 PM
  #52
Hendrik Koster's Avatar
Top Answer: 1
2007 S65 AMG-Sold, 2007 SL55 P030 - 2016 GL450 - - 2017 AMG GTS - Sold - 2015 AMG S65
Your transmission uses ATF not Pentosin
Pentosin is the fluid for the ABC system!
Ok you used P-transmission fluid you should not have to add 1 liter unless it wasn't filled to the right level before
Old Mar 21, 2020 | 09:34 PM
  #53
2006 S55 AMG
Pentosin ATF 134
I used Pentosin atf 134. I haven’t gotten the transmission serviced yet, just the abc.
Old Mar 21, 2020 | 09:41 PM
  #54
2006 S55 AMG
Atfnlevel
[QUOTE=Jdfreak2012;8013544]I used Pentosin atf 134. I haven’t gotten the transmission serviced yet, just the abc.[/QUOTE
im Just wondering how much atf fluid it should take to raise the level on the dipstick from around 3/8” below the low (when warm) to full? I want to make sure I’m checking the level right.
Old Mar 22, 2020 | 11:30 AM
  #55
2006 S55 AMG
NVM I got it.
[QUOTE=Jdfreak2012;8013547]
i had to figure out I needed to push the dipstick past the last bend but not be a gorilla and make it turn and lay in the bottom of the pan. I had to take 200 ml back out but it’s good now. Shifts a lot better, up and down.
Old Mar 22, 2020 | 11:54 AM
  #56
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
[QUOTE=Jdfreak2012;8013779]
now that you know the level of fluid was the problem, I'd say run it 500 miles then flush it all and refill with new filter. Then you'll know the quality of fluid is good too.
maw
Old Mar 22, 2020 | 12:19 PM
  #57
JohnLane's Avatar
222 S-65
[QUOTE=maw1124;8013788]
maw
I drain and refill my trans every second or third engine oil change.
Noticable improvement in shift quality with fresh fluid.
Old Mar 22, 2020 | 12:22 PM
  #58
maw1124's Avatar
[QUOTE=JohnLane;8013815]
John, I presume that's because of time, not mileage. 3 oil changes could be 5 years for some people, me included. On some of these cars it takes me 2 years to put 5k miles on it.
maw
Old Mar 22, 2020 | 12:26 PM
  #59
JohnLane's Avatar
222 S-65
[QUOTE=maw1124;8013819]
maw
My car gets 20,000 miles annually. I change oil every 5000-7000.
I wipe the dipstick on a paper towel to decide if trans oil is ready + the sniff test.
Old Mar 22, 2020 | 12:37 PM
  #60
maw1124's Avatar
[QUOTE=JohnLane;8013822]
got it. The longer I own this car the less I drive it. I think it had 90k ish around 2012. Now it has 135k ish. I try to do every 5k oil changes just so I can keep up with them. Sometimes that's annually, sometimes not. But trans fluid and plugs every 5 years is easy to remember.
maw
Old Mar 22, 2020 | 12:41 PM
  #61
2006 S55 AMG
2006 S55 AMG
Thanks for the advice. I’m getting less scared of this car (first MB). I’m finding that these Mercs are really well built and reliable. As a mechanical engineer and German descent, I appreciate the math and dedication necessary to appreciate these machines.
Old Mar 22, 2020 | 12:44 PM
  #62
maw1124's Avatar
[QUOTE=Jdfreak2012;8013837]
it's just discipline within a HUGE margin of safety. As you see, they can handle some neglect and spring back. With no neglect they go forever.
maw
