Ignition problem
Ignition problem
Hi all, any help would be greatly appreciated, I have a 03 s55 amg let it sit over winter with battery in, not good replaced the battery, all lights work, radio also, no horn and when I put the key in the ignition it will not turn and also it blows the 7.5 fuse that's located on passenger side front seat fuse panel, has any one ever had this issue?
Solved, I took my 7.5 fuse out that kept blowing, the reason was the car was in anti theft mode, every time I put in a 7.5 fuse it would blow, couldn't figure out why so I put in a 15 amp fuse, .low.and behold the key turned, so before I started the car I cleared the code that was in my scanner, the took out the 15 amp fuse I had in and replaced it with the 7.5, which the 7.5 didn't blow like before, so then I started the car with the 7.5 fuse in, only so I wouldn't cause some other catastrophic event on this thing, and now were up and running,, I love my BENZ!!!
