ABC Woes
Old Aug 13, 2020 | 09:27 PM
Byte's Avatar
S55
ABC Woes
Hi all,
I have an S55 that one day called out ABC. The front left strut was replaced, and so were the level sensors.
My scanner is capable of doing the level programming. Autel maxisys
My current process is:
plunger automatic calibration: Says it’s successful after going to max height, then says preconditions not met. But no code for a failed plunger cal.
level cal: I set the front to 26 3/4”, rear to 27 1/2”. This sets my level sensors voltage happy. I don’t have the 5k gauge for the inclination angle, so I say 5° up front, and -1.5° rear. Level cal successful.
load adjustment: Raises the front, lowers rear right and then says successful.
The load adjustment seems to throw everything off, since it jacks up the front. If I don’t do a load adjustment the car rides at the level set from before. After the load adjustment the car runs at -45mm up front and 0mm at back (live ride height data).
Is this because my inclination angle is made up?
What also confuses me is the “-45mm”, but the car is riding higher than “0”. I swapped the level sensors left to right to see if they were reading upside down. But no change. I have the sensors fitted to the aft side of the mounting bracket. Its been months since I removed the stock ones, so I can’t remember if they were forward of the bracket. Any tips would be appreciated.
Old Aug 15, 2020 | 04:05 PM
Janissaire's Avatar
none of those for now
Hello,
https://www.benzworld.org/threads/st...alues.1648658/
https://mbworld.org/forums/sl-class-...libration.html
https://www.google.com/search?client...UTF-8&oe=UTF-8 i know those aren't the same car but it might help you anyway. Supposedly the wis/das/star system can do the adjustment automatically but if your "front up wishbone" are of the wrong weight, it will not work, anyways don't take my word for it as i am no expert on this.
Cordially.
Old Aug 16, 2020 | 02:47 AM
JohnLane's Avatar
222 S-65
Here.... I'll try..... "Search nOOb!"
That's a joke.
OP I hope you are able to get it resolved. This kind of stuff can be soooo maddening!
Old Aug 16, 2020 | 03:03 PM
Byte's Avatar
S55
Thank you for the help so far. I have indeed followed the romes angle procedures correctly now. No change
I believe the issue lies in the level sensors reading upside down. They’re correctly positioned, I’ve swapped them left to right. No change.
Old Aug 31, 2020 | 02:20 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
Did you figure this out? I have same issue but I gave up and dropped it to the shop
