HELP: A/C and Heat
Old Jan 13, 2021 | 07:59 PM
The Judge's Avatar
2005 s55
HELP: A/C and Heat
Gents,
Need your help/input. My s55 blows heat, but not in the top center dash. All I'm getting is cold air.
I have watched YouTube videos and have read up here on MBworld, but must be doing something wrong still (sigh).
- What is the procedure to get the top center dash vents to mirror the main control by the stereo?
I do have heat in the floor and on the side vents at the same time, but not in the top center vents ) just getting outside air....and I have the top center control set to “auto”. I have also adjusted the top vents from small dots to large dots, but still get cold air and the A/C is not turned on (no red light).
Old Jan 13, 2021 | 08:32 PM
GrepAwk's Avatar
'03 S55 (79K miles)
Me too. Since new.
There has always been a cold fresh air draft from the top center vent when trying to get warm air, if the scroll wheel dial is left on Auto.
I have never solved the problem; just kept tweaking to make it slightly less annoying.
Old Jan 13, 2021 | 09:02 PM
The Judge's Avatar
2005 s55
I'm genuinely just trying to understand the nuances and getting input from other owners helps.
Really appreciate your response.
Old Feb 18, 2021 | 07:47 AM
ls1_mast's Avatar
w220 S55 AMG 2004
actually what GrepAwk said is true . as long as the middle wheel is on auto it will change based on the inside temp. so sometimes it will blow hot air if u already reached the desired AC temp . and sometimes will reverse
Old Feb 18, 2021 | 03:02 PM
wfooshee's Avatar
2007 Jaguar XJ8L, 1999 Miata, 2003 Yamaha FJR1300
What they said. Take that middle wheel off of auto. I don't understand why those vents can regulate separately from everything else in the car.
