My complete build log: 2002 S55 AMG 5.4 N/A
Old Mar 3, 2021 | 03:37 PM
Biig AMG's Avatar
2002 S55 AMG catless, x pipe, Brabus mufflers, coilovers, and driven like hell
Hey everyone, I'm creating a build log for my car and will show as much as possible for the current progress, and future progress.
YouTube Link:
https://youtube.com/channel/UCOP1DY7dvBA6xV15rPExEMg
This is my 2002 S55 AMG, with the M113E55 5.4L N/A motor. 354HP 391ft-lb
040 Black
Bought at 100k miles with new radiator and freshly rebuilt trans for low price because it needed lots of maintenance.
As I create this thread, the car now sits at around 128k miles after about a year and a half of ownership, with most of the maintenance taken care of and some light modifications.
I love this car more than anything, I bought it as an AMG enthusiast at 20 for really cheap and to learn my way around every little detail about it. I wanted to be unique and start with something most people wouldn't.
Most people don't modify their S classes, plus this is a prefacelift W220 AMG, those get no love. Everyone says to supercharge it or M113K swap or just get an M113K car, but what's the fun in doing what everyone else does?
Once all is said and done, I want my engine bay to look completely stock, with the stock airbox.
If anyone has any questions, feel free to let me know.
Current modifications include:
Gutted Airbox with drop in filters
82mm Throttlebody
Full cat delete
X pipe
resonator delete
Brabus mufflers
Strutmaster Coilovers
Complete ABC system delete
Vtech Georgia Tuned TCU
VTech Georgia ECU tune
Next Mods:
Injectors
Long tube headers
3" exhaust with X pipe to Brabus Mufflers
New adjustable coilovers
Maintenance items performed (All done by myself)
Oil and filter Changes every 5000 miles ish
110,200 miles:
Radiator flush
Transmission flush
Diff flush
Serpentine belt
Tensioner
Crank position sensor
Motor mounts
Trans mount
Service position
First time getting a good look at the engine
First time getting her up on a lift
First big set of services done
116,000 Miles:
Oil change
120,458 Miles:
Oil change/oil filter change
Starter motor replaced
After replacing starter motor
123,313 Miles:
Oil change
Airbox gutted and air filters replaced
Spark plugs replaced
Flex discs replaced
Upper radiator hose replaced (grazed the fan and spewed
127,444 Miles:
All front control arms replaced
tie rods replaced
Sway bar and brackets installed (had coilovers but no sway bar for a while)
New control arms and sway bar installed
ABC/Power steering tandem pump replaced with W210 E55 AMG Power steering pump
Cleaned engine bay from oil and grime
Got rid of the complete ABC system
power steering system flush
Cooling system Flush
Before disassembly
Cleaning up the oil and gross from my engine
Getting better
Issaight
Mostly assembled
Simplifying everything, cleaning it all up behind the bumper and got rid of all of the ABC components
Fully reassembled
Back together
Next maintenance to perform:
brake rotors and pads
due for fluid flushes again (besides radiator and power steering)
due for oil change
Oil cooler seal replacement (only oil leak I have)
129,408 miles: VTech Georgia tuned TCU/ECU
Update as of July 2021:
The car has been through a lot since the last update. It was crashed on April 10th and required pretty much a whole front end rebuild around 129,200 miles. The car sat for around a month and a half before it was drivable again.
Took me almost a month to get an oil pan and make sure the motor still ran. Pictures of the rebuild will be below.
Destroyed:
Fenders
Bumper
R Steering knuckle and hub
R Lower control arm
Both front wheels and tires
Oil pan
Radiator
A/C Condensor
Right headlight
The repair process:
Old Jun 18, 2025 | 05:03 PM
W220DMV's Avatar
Pressure hose
when you put the power steering in what pressure hose did you end up using? I’m having problems finding a non abc pressure house. can you please let me know what hose you ended up using. I also have a w220 s55 5.4 n/a
