S55 A/C Bypass Belt
Old May 10, 2021 | 01:35 PM
paste's Avatar
S55 A/C Bypass Belt
Is there a belt that could be used to bypass the A/C on the S55? I just tried the 6PK2360 and it was too small so I returned it. I think it is because the ABC pump pulley is larger than the cars that use regular p/s or something because that is what that belt is supposed to be for.
Thanks.
Old May 10, 2021 | 04:28 PM
wfooshee's Avatar
2007 Jaguar XJ8L, 1999 Miata, 2003 Yamaha FJR1300
You're not going to be able to bypass the compressor with it in place. In the WIS diagrams, the belt path is the same either with or without air conditioning, but when without, there is a small idler pulley near where the compressor should be. It's a much smaller pulley than the compressor's pulley, and it's much closer to the crank pulley than the A/C compressor is, which might be the setup you had a belt for. The rest of the path of the serpentine belt is identical. Basically, there's no "going around" the A/C compressor.
Old May 10, 2021 | 05:21 PM
paste's Avatar
Okay.
