Another ABC red message delete issue.....not what you may be thinking
Old Sep 28, 2021 | 10:15 AM
mercedes driver's Avatar
2005 e320 cdi
Yes, i have searched and looked all around this site but one of two things has happened. Either i really suck at using the search feature, or there is nothing specifically addressing the issue i am having.
This involves a 2003 S55 W220. Now i have no idea if this makes a difference but the common suggestions for pulling the # 9 and 46 fuse does not work for my model. If the fuse on the passenger side is pulled the car will not start(believe acc position works but won't actually switch on in cranking/run position), and if the fuse on the driver side is pulled the radio will not work. Pulling either, or both, of the fuses does not remove the red ABC warning.
So is this an issue unique to the s55 or have i just not properly understood which fuses to pull?
