W220 Mercedes flushing lights after locking
Old Oct 10, 2021 | 07:21 PM
Shax Shux's Avatar
2003 S55 Kompressor
Hey guys, what do you think is the problem here? Most of the time when I lock my vehicle high beam lights are flushing for a few minutes then it shuts off. Also, panic button isn't working on a key fob. Do you think it's an alarm siren issue?
Thanks!
Old Oct 11, 2021 | 11:14 PM
GrepAwk's Avatar
'03 S55 (79K miles)
Flashing or flushing?
Do your lights flash literally for a few minutes after you lock the car with the key fob?
That’s the sign of your alarm sending an intrusion detection. Ie, you tripped your alarm.
My lights flash twice when I arm the alarm, and then they stop after one second.
If I hold in the panic button on the fob for 3 seconds, the headlights flash and the siren sounds from the vehicle for a few minutes.
if you hold in the panic button and get nothing, then your vehicle is not recognizing the fob.
Not sure what the problem is.
Do you ever hear the alarm siren sounding?
If not, you might need to replace the siren horn in the left front wheel well. It includes a built-in rechargeable battery that goes bad after 10 years. You will have to remove the front left wheel well liner to get to it.
Old Oct 12, 2021 | 11:13 PM
ChampagneC's Avatar
Grep is accurate - you need to replace the alarm siren. I think my mechanic did it for like 200ish installed
Old Oct 13, 2021 | 12:50 AM
Shax Shux's Avatar
2003 S55 Kompressor
Yes flashing headlights. Do you have to replace the whole siren or maybe just a battery?
Old Oct 13, 2021 | 11:46 PM
ChampagneC's Avatar
its a sealed unit and you cant replace just the battery so whole thing must be swapped
