S55 wont lock its doors at all
Old Mar 26, 2022 | 12:08 AM
TrippiesRevenge's Avatar
2004 S55 AMG
Angry S55 wont lock its doors at all
So I bought this S55 with both rear door lock actuators broken. I recently bought another door from a different W220 car. To get the old door I basically had to cut around the outside door handle to manually open the door. this new door did not have the big bright blue cable and the housing so I switched it over from my old door and put the entire door together. after I was done I go to see if the door actually locks and unlocks, which it does lock but then when you press on the key fob to unlock it the little manual switch to unlock the door goes up very slowly, barely even that i have to lift it up with my fingers to be able to open the door, that is a different problem but i feel like i had to point that out. everything seemed fine all the other doors locked and unlocked except this minor problem , I go out and when I come back I try to lock the doors and check if the new door locked correctly and it did not. after looking at all the other doors they did not lock either with the keyfob or with the buttons inside the car and the manual switches on the car doors wont go up or down anymore like they used to. all the other doors worked fine and now after installing this new door the others do not want to open which brings me to believe the problem is central. i would really appreciate some help as i cannot lock the car in any way and its just sitting out there!!!!!
Old Jun 8, 2022 | 02:25 AM
HJAMES608's Avatar
2001 S55 AMG
If none of the doors will open or close with the remote, it sounds like it could be the PSE pump in the trunk gone bad. This controls all the functions of the entire system. Does the trunk lock and unlock? Does the soft/close function work? When you press the remote buttons, do you hear the pump running?
