02 S55 ABC questions
Threw up a few cones and did some slaloms, and while it does not handle like a Miata, it feels pretty good.
The question, is what should the measurement be from the wheel lip molding to the ground.
I have 27.5 to 29 inches on the driver side depending on switch position. The passenger side responds the same, but is always about 1.5 inches lower.
All of the right front suspension was changed except the strut. Rear suspension was not touched.
The car will settle all around after 4 days or so, but stays in the same position over night.
I have to drive it in the first raised position, but it will occasionally rub the right rear tire slightly.
Does this call for a suspension relearn, or do I need to look for another issue?
