Coil binding after ABC conversion
Old Jun 21, 2022 | 12:26 PM
paste's Avatar
I was wondering if anyone has experience with the coilovers conversion, specifically the Yellowspeed's. I'm getting what appears to be cool binding on the fronts when I turn the wheel while the car is stationary. I have made a short video and you can hear the noise. I've gone over the install and don't see any apparent issues. The noise is not noticable outside of the car, it's really on felt/heard when turning the steering wheel inside the car.
https://youtube.com/shorts/EXnqPwPbRMg?feature=share
Old Jun 22, 2022 | 04:20 PM
lthlc63's Avatar
04 E55, 06 E55, 05 G55, 14 E63s, 12 cls63
Usually when this happens it means the coil isnt seated properly on the top mount, thats whats causing it to make weird sounds.
Old Jun 23, 2022 | 09:02 PM
paste's Avatar
I didn't mess with any of the preload until I noticed this. Also, I ended up loosening some of the preload by just a bit and it still is making the sound. I noticed that the rears also make the noise as well so I am fairly certain that it is not related to the steering. The preload settings were supposed to be set by the manufacturer so I don't think it should be making the noise.
I have read on the Toyota GR86 forum that this sound can be expected with coilovers although some people have had success with making some adjustments to get rid of the noise.
Old Jun 24, 2022 | 01:21 PM
lthlc63's Avatar
iv had over 30 cars and installed coilovers in all of them. the one time i had a sound come from them was due to the mounting point. its worth checkout out
Old Jun 24, 2022 | 06:41 PM
paste's Avatar
Where it mounts to the frame or control arm?
