Supercharger Pulley
Old Oct 23, 2022 | 09:34 PM
CICBarkeep's Avatar
2005 S55 AMG, 2001 SL500
Supercharger Pulley
I recently bought an '05 S55 AMG with a RaceIQ Stage II tune and an 83mm fixed pulley installed and am considering reverting back to the OEM clutched pulley that came with the car. Question is this: If I revert to the OEM pulley does the tune need to be reverted as well? Thanks for your help, CICBarkeep
Old Oct 23, 2022 | 10:29 PM
GrepAwk's Avatar
'03 S55 (79K miles)
Probably
The smaller pulley would have had the effect of increasing the air input. A resultant increase of fuel would have been called for to keep the air:fuel ratio right, which is why prior owner got a tune.
Decreased air would beg for decreased fuel, which is supplied by the injectors which would be controlled by the ECU, that would have been tuned away from stock levels.
so, going back to OE air would require going back to OE air:fuel ratios and thereby stock tune.
Old Oct 24, 2022 | 07:51 AM
CICBarkeep's Avatar
Supercharger Pulley
@GrepAwk Thanks for the prompt response and confirmation of my suspicions. I appreciate what the PO was after, but the supercharger rattle at idle just rubs me the wrong way. I guess I'm left with two options. Clutched 83mm pulley or revert to stock configuration across the board. Any thoughts?
Thanks again.
Old Oct 25, 2022 | 08:24 AM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
Thanks again.
I know the car and prior owner well. You can go either way for about the same price. A clutched 83mm pulley will cost you about the same as a used OEM pulley (which isn’t as ridiculous an option as it might first appear).
I am running the same setup, and knowledgeable people have told me they’d rather have a fixed pulley (linear power, no clutching engagement). It’s all preference in my opinion, but if the rattle is that big a problem (trust me, I understand, I’d have a fixed one if it wasn’t for the rattle), the simplest thing to do would be a new 83mm clutched pulley — same belt, same tune.
I’m sure PO gave you the stock tune file (or will if you just ask him), so you have that option available as well.
GL
maw
Old Oct 31, 2022 | 10:24 AM
CICBarkeep's Avatar
Part of the fixed pulley install included wiring a resistor "into the harness side of the supercharger plug so that clutch and ECU will think the clutch is engaged at all times." I'm assuming that resistor will need to be removed with the installation of a clutched pulley but have no clue where to look or how to go about deleting it. Any help appreciated.
Old Oct 31, 2022 | 02:20 PM
ls1_mast's Avatar
w220 S55 AMG 2004
as far as i know the fixed pully can be installed without the resistor and command the ECU to ingage the supercharger pully all the time . thats is why its rare to me to see this resestor installed , however since the old owner already installed it , i found one video that mentioned the resistor. i'm not sure that it will help but here is the link to it
